Results 1 to 10 of 291
May 4th, 2013 01:41 PM #1
Please help me choose a printer. It will only be used for printing documents (word, excel or ppt) and web pages.
My previous printer was a Lexmark and has gone through my graduate and post-graduate papers! It's still working but the cartridge is already obsolete and I have gone through several refills on my last cartridge. It served me well for 12 yrsI need to replace it now with a printer that is basic since I rarely print documents. My budget is only 3k maximum. My priority is is durability.
Here are my choices:
Canon Pixma iP2770 Printer PHP2195
Canon Pixma iP2770 Printer | VillMan Computers
Print
Speed*1
Based on ISO / IEC 24734.
Click here for summary report Black & White: A4 Plain Paper: ESAT: 7.0ipm
Colour: A4 Plain Paper: ESAT: 4.8ipm
Photo (4 x 6"):
PP-201 / Standard / Borderless 55secs.
Resolution (dpi)*2 4800 x 1200dpi (max.)
Min. Ink Droplet Size 2pl
Number of Nozzles 1472
Cartridge Type PG-810, CL-811 (PG-810XL, CL811XL Optional)
Epson Expression Home ME-10 PHP2495
Epson Expression Home ME-10 | VillMan Computers
Small Footprint – World’s smallest printer in its class; Designed to be 15%
smaller than the previous models T13 and ME 32
• Footprint refers to the desk area the device’s occupy
• Low Cost per Cartridge – New economical Inks for only PhP 185 per
black ink cartridge and PhP 355 per color ink cartridge
• Individual Ink Cartridges – Replace only the color that is already ink-out
• Peace of mind with extremely reliable Micro Piezo Print Head technology
• Improved Productivity with print speed up to 24ppm
Print Speed (ppm)
24 / 13 (black / color)
Dimensions
15.4 x 19.6 x 11.2 in
HP Deskjet Ink Advantage K010A Printer PHP2990
HP Deskjet Ink Advantage K010A Printer | VillMan Computers
Specifications
Print speed black (draft, A4) Up to 20 ppm
Print speed colour (draft, A4) Up to 16 ppm
Print speed footnote Speed specifications have been updated to reflect current industry testing methods.
Print speed black (laser comparable) Up to 5.5 ppm
Print speed color (laser comparable) Up to 4 ppm
Print quality black (best) Up to 600 dpi
Duty cycle (monthly, A4) Up to 1000 pages
Number of print cartridges 2 [1 black, 1 Tri-color (cyan, magenta, yellow)]
Print quality colour (best) Up to 4800 x 1200 optimized dpi (from 1200 dpi input data when printing from a computer on photo paper)
Standard memory Integrated
Standard printer languages HP PCL 3 GUI
Paper handling
Paper handling standard/input 60-sheet input tray
Paper handling standard/output 25-sheet output tray
Duplex print options Manual
Maximum input capacity (envelopes) Up to 5 envelopes
Borderless printing No
Media sizes supported A4; B5; A5; A6; DL envelope
Media types supported Paper (brochure, inkjet, plain), photo paper, envelopes, labels, cards (greeting), transparencies
May 4th, 2013 01:53 PM #2
Meron ako nung canon pixma, pinaconvert ko siya sa unlimited ink and I buy refill ink which costs 70petot sa recto. Isang refill ng ink kaya magprint ng up to 2,000+ pages. Haha.
May 4th, 2013 09:19 PM #3
Here's the problem. Ink jet printers are cheap. But you will need to use them often enough so the ink will not dry up in the nozzles/print-head.
The solution, get a LASER PRINTER. The cheapest ones are around P3,500 each with a toner capacity of around 1500 copies. You can leave this unused for a whole year then fire it up for a quick document print out with no issues (except if a rodent or family of roaches made it as their home).
May 4th, 2013 09:20 PM #4
May 4th, 2013 09:36 PM #5
correct ka dyan sir GH, don't buy cheap refillable inks baka masira pa printer mo.
May 4th, 2013 09:40 PM #6
^ natetengga din yung akin pero di pa naman sira. Going 3 years na siya. Downside lang is naglileak na yung ink ngayon. Oh what the heck, hinihintay ko lang naman na masira na ng tuluyan para bumili ako ulit nung 3 in 1. Haha.
Basta kahit ano mangyari wag na wag kayo bibili ng brother na printer, nakatatlo na kami at nasira lahat.
May 4th, 2013 10:08 PM #7
At our office, since we need a printer for color, I got an EPSON L100. It was fine in the most part except it was quite slow.
Previously we used a Canon IP1800 series printer with ICS kit. It worked fine except that I needed to replace the cartridge (color or black) around every 3 weeks or I had to run cleaning cycle often to keep the prints clear and bright. Basically it needed quite a bit of attention from me.
The EPSON L100 was better in that it only needed its ink refilled and that's it. Once in a rare while, I might need to do a cleaning cycle but it's still a far cry from what I was doing with the Canon. Since the L100 was slow and we needed color prints quickly, I bought another unit, an EPSON L110 which was it's newer model and a bit faster too.
May 4th, 2013 10:37 PM #8
Laser printer HP would be the most practcal. Sa colored laser...i use brother
May 4th, 2013 11:09 PM #9
Kailangan ko na rin ng bagong printer, pangit na output ng printer ko ngayon. Same lang sa needs ni cathy, document printing, usually b&w pero syempre may colored din once in a while.
Ano kaya pinaka-ok na laser printer tapos under 4k? Ok kasi sinabi ni GH, pwede iiwan ng matagal na hindi natutuyo, thats what i need.
Sent from my 3210 using Tapatalk HD Premium
May 4th, 2013 11:37 PM #10
Bat pa i-share vid niya rito kung sa tingin personally na ka-duda˛ o wala pala siyang credibility...
The Toyota Fortuner has landed (fortuner pics at...
