Results 91 to 100 of 321
June 5th, 2010 10:12 AM #91
uls, how much mo nabili APAD? May flash na kaya yan? Maganda pang internet browsing on the bed yan kung sakaling may flash support na.
Ok rin pang movie on the go.
June 5th, 2010 10:23 AM #92
boybi, eto yung specs:
Product Configuration
CPU VIA8505
Main Frequency 300MHz
System Andriod 1.7
Language Multilingual
Input Method android keyboard&Google Pinyin input method
Touchscreen Full mirror face, HIGH sensitive touch screen operation
Built-in touch panel,support USB port
Display screen Size 7" PANEL
Resolution 800*480 WVGA
WiFi connection Wireless: IEEE 802.11b/g
Battery capacity 1500mAh/7.4V
Headset jack 3.5mm Standard Headset jack
Power adapter 9V/2A
USB Port 1*MINI 5PIN USB PORT
Speaker 2*Built-in Speaker 8Ω/1W
Storage deck External TF card expansion,
product size 230mm*137mm*13mm
Cruise duration 2.5HRS
June 7th, 2010 10:22 AM #93
question, puede na ba live stream audio sa ipad 3g? for example, i want to listen to magic 899 etc.
kung hindi, sa ibang tablet with android OS kaya ba?Last edited by Negus; June 7th, 2010 at 10:26 AM.
June 7th, 2010 01:13 PM #94
*Negus, as long as there's internet, pwede (as long as hindi flash based yung station).
ako naman, I use TuneMark app for IP radio streams.
June 19th, 2010 10:16 PM #98
pa share naman ng experience....ok naman sya?
may nag aalok kasi sa akin dito. pero i think mas mura pa rin ang bili ko. here its 1400hk$ or around 8k pesos.
sa pinas daw ang bentahan is 15k.
June 19th, 2010 11:15 PM #100
di ko gusto yung touch screen
hindi sensitive
kailangan medyo madiin
battery life isnt good
it's ok
pang check ng mail, browse
di ko pa nalagyan mg music or videos
yep, around P15T dito
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
