Results 1 to 10 of 28
May 9th, 2006 06:44 PM #1
anong tamang psi nang gulong sa mid size SUV na 16 inch stock ang gulong.
para hindi sya matagtag at matalbog
May 9th, 2006 06:50 PM #2
naka indicate usually ang tamang PSI dun sa side-walls ng gulong. depende rin sa load ng sasakyan i.e. kung gaano kabigat ang nakasakay/nakakarga sa sasakyan mo when you take a PSI measurement. factor din ang lapad nung gulong.
May 9th, 2006 06:52 PM #3
ang nakalagay is 32psi.
nag 35psi ako at nitro nilagay ko ang problem ko lang nagpakarga nang hangin yung driver ko kanina nilagay ordinary nilang nalimutan daw nya nakanitro.
May 9th, 2006 07:01 PM #4
kung ayaw mong matagtag... bawasan mo ng konti ang air pressure... kung 32 psi ang recommended... gawin mo lang 30 psi.
comfort (lower tire pressure) vs. fuel economy (higher tire pressure). medyo tolerable naman ang +/- 2 psi sa mga gulong.
May 9th, 2006 07:05 PM #6
hindi naman... ordinary air is already composed of around 75% nitrogen.
hindi mo lang ma experience yung benefits ng nitrogen-filled tires (if there is any).
May 9th, 2006 08:43 PM #8
Sa tingin ko lang advantage so Nitro is for the long distance driving lang siguro kasi Nitro when heated up will not expand or inrease tire pressure unlike the ordinary air the longer you drive more prone to tire burst if not monitored properly. Ewan ko lang riding comfort kung nakakatulong to
- Dec 2002
- 2,335
May 9th, 2006 08:50 PM #9at cold temps around 2 psi lower ang readings. Nitro is not really affected by varying temps so you maintain the correct tyre pressure. Follow the mfgs suggestion. Tama yung mga comments, kung matagtag lower the tyre pressure but gas consumption will be affected a little bit.
- Oct 2005
- 177
any car can handle navigating to Baguio basta nasa condition. kahit nga trike pwede din hehehe....
2023 Ford Everest Owners Thread
