Results 1 to 10 of 35
July 24th, 2005 12:22 AM #1
I'm currently running 33x12.5R15's on my stock 15x7's and around 1.5"-2" of suspension lift. While this has worked quite fine, there is rubbing with the front swaybar at full turns to lock and that the ideal wheel for my tires as 15x8's.
I'm now pondering which direction to go.
Option one: Go with with aftermarket 15x8 wheels (similar in style to KCboy's/Angelo's) and stick with 33x12.5R15's.
Option two: Go with with OEM Pajero (either 'standard' or RALLIART) wheels and fit 285/75R16 tires (they fit without rubbing at full turn-to-lock, right?).
RALLIART:
*STANDARD*: SEE NEXT POST
Now for some questions:
1. Which do you think is the best option?
2. How much does a typical set of five 285/75R16 mud tires go for nowadays?
3. How much does a set of 5 Ralliart or standard alloy go for nowadays (new or used)?
Thanks so much.
July 24th, 2005 12:23 AM #2
July 24th, 2005 09:44 AM #4
tire rubbing , i dont care if i have a Pajero. Its my dream car in the Phils. Here I can afford that times two.
July 24th, 2005 03:42 PM #5
i would suggest that u just go n buy a new set of 15x8 rims since it would be cheaper, la pa 20k, rather than getting a new set of mt tires na 16in. masmapapamahal ka pa, sayang naman yung 15 in mt tires mo.
Tsikot Member Rank 4
- Oct 2004
- 2,315
July 25th, 2005 08:03 PM #8
For the budget... upgrade to the 15X8's. ;)
If not... why not go bling bling? HEHEHEHE. :P
July 25th, 2005 10:07 PM #9
mawawala naman ang rubbing pagnagpalit ka into steel bumpers. so....so with the 15x8 and 33s. sayang naman tires.
July 25th, 2005 10:18 PM #10
I'm rubbing the swaybar, not the bumper. Offset talaga problema ko.
33x12.5R15 GT Savero Muds sell for Php 5,900.00/ea. sa Tomas Mapua.
Nag try ako mag inquire ng Leoch brand sa FB page nila. The price is not cheap. Yung available for...
