Results 1 to 10 of 27
October 25th, 2004 02:12 PM #1
My ride is a Pajero 97 TDIC Local unit, ater having it car washed (engine, underchassis and body wash), I noticed that the front wheel indicator lights are blinking and when I shift to 4wd and return to 2wd, it still is blinking.
Otep and/or Joseph (Pajero Expert) can you help me on this?
Thanks...
P.S. I visited other threads, similar to this, but so far, no answer has been provided...
- 10,620
October 25th, 2004 02:57 PM #3
same thing happen to me..but after a while okey na, ang nawala ngayon ay yung light ng temp/compass beside ng altimeter, i know its a seperate bulb yun (mag-kasama ung dalawa) pano ba palitan yun DIY.. thanks
Tsikot Member Rank 4
- Feb 2004
- 1,704
October 25th, 2004 03:01 PM #4yup, malamang nabasa ang solenoid. try mo muna linisan ng contact cleaner, baka basa lang.
DON'T buy the slenoid from the casa. ANG MAHAL!!!!!!
maghanap ka sa iba
andy
October 25th, 2004 03:25 PM #5
Pajoz, i-search mo yung thread ni Otep regarding replacing the compass bulb. May input din ako dun. You will have to replace two bulbs for the Gen2.5. Sa eldorado ako nakabili forgot the price though.
October 25th, 2004 04:55 PM #6
Thnks PK, I rememeber i've read this topic before, anyway search ko na lang.
October 25th, 2004 06:47 PM #7
eto yung link sir Pajoz....
http://tsikot.yehey.com/forums/showt...&threadid=9129
October 25th, 2004 07:09 PM #8
Thanks uli SIr Pk, Nakita ko na... found this site also.
http://www.pocuk.com/faq/compasslight.htm
- Nov 2004
- 115
August 15th, 2005 09:51 AM #9makikipost lang with same issue.
blinking 4 wheel indicator problem.
- checked solenoid valve. ok naman. i removed it from the engine bay and clean it. put external power source and oks naman.. i tested it while engine is running, oks naman ang vacuum. so no problem sa solenoid.
- checked the actuator, if you changed from 2W to 4W and from 4W to 2W, I can feel na nagtotoggle while holding the boots. So my guess is ok din ang actuator. Anybody tried this? I wonder kung ung toggle ay parang push and pull or dapat parang hydraulic na swabe ang pag in and out ng bushing?
- checked the hose, pero wala namang crack.
- what else could be wrong? i still get the blinking lights.. could it be the freewheel engage switch?
- anybody tried removing the freewheel clutch assembly?
- whats causing the indicator to blink? is there a sensor somewhere?
thanks!
- Jul 2005
- 83
August 15th, 2005 10:03 AM #10Originally Posted by the_possessed
baka nag stuck ang auto hub,try mo atras and pajero mo mga 10meters baka mawawala un ilaw.
Xiaomi E-Car
