Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Aug 2005
    gud evening everyone, juz registered today. to my fellow cebuanos, do you have any idea where to buy a mobil 1 0w40 here in cebu? the shops i inquired so far only have 5w50, some even dont know dat a 0w40 even existed. pls do reply! thank you!
    Feb 2005
    if i may ask, what ride are you going to use that Mobil 1 0w-40 oil??
    WBR,
    Jun 2005
    try this store (forgot the name), i think they are a distributor of mobil oils. its along the corner entering ayala access road coming from mandaue. basta, there's a mobil 1 sign.
  4. Heretic Guest
    Aren't oils with a 0 winter grade commonly used in countries with freezingly cold weather?
    Feb 2005
    Yes, but that's what Toyota dealers are recommending for 1k PMS of all brand new cars now..
    WBR,
    Aug 2005
    2004 honda civic vti-s 1.6....thanks soo much knight23 for the info... by the way I called up a shop in v. rama kanina, they have a mobil 1 0w40, pero by order basis lang daw. soo expensive, P2650/ gallon.
    Quote Originally Posted by Innova_Boy
    WBR,
    Recommending motor oils for freezing temperatures in a tropical country, do the guys at Toyota really know what they're doing?
    Feb 2005
    Quote Originally Posted by falken
    I presumed not, cause primarily they are after huge profits just like the case in Fortuner woes thread..
    As long as they guarantee your ride, then maybe ther's no problem with me IMO...
    WBR,
    Feb 2005
    Quote Originally Posted by babymim
    wow that's around P662.5 per liter...
    I got my self some months ago of this oil for only P450 per liter.. not from toyota delaer...just from a friend at Banawe...
    WBR,
    Aug 2005
    di talaga ma-reach, sobrang mahal... that leaves me with two choices nalang: honda fully synthetic (P2200) and havoline fully synthetic (P2400)... ayoko talagang mag honda oil kasi SJ lang yung api rating nya...i havent read reviews on havoline fully synthetic yet, la ngang nag-reply sa thread ko about it.
    Wala ba sa CFG?, if nobody has it, you can use the 5w50 one, it's more suitable for our country's climate, yung 0w40 is better suited for Countries with colder climates. Kaya wala sguro masyado nagbebenta ng 0w40 na Mobil1 dito.
    Aug 2005
    puro castrol lang ang cfg....no w50 muna ako as of now, it might void my warranty kasi walang mga w50 na recommended viscosity sa manual...as much as possible i'd go for w40 kasi di masyadong manipis, di rin masyadong malapot.
    Nov 2003
    falken, i think you should try to research muna on oils. don't think you are clear about how they work or the ratings.
    indeed, we don't get close to winter here so the 0 in the 0w40 isn't used. but neither do we get close to 5 degrees, so useless ba din yun?
    look at the second number, that's number is more indicative of the purpose of the oil you should be using.
    0 means it's stable to 0, but it doens't mean it doesn't work for our temp, 0W40 means the oil remains the same in terms of protective qualities whether the ambient temp is 0 or 40deg.
    Quote Originally Posted by speedyfix
    Speedyfix, please correct me if I'm wrong, from my understanding, the 1st number is for oil that meets low temperature requirements , and the second number is for high temperature requirements, so in a warm country like ours a higher 2nd numbered oil will suit us better? I'm currently using 5w40 oil on my van, wala namang heavy load or extreme driving conditions, pwede na ba yung viscosity na yun?
    Apr 2005
    Unsurpassed protection for multi valve engines
    Helps keep your engine running like new
    Improves engine protection during critical start-up period
    Excellent high and low temperature performance
    Proven low fuel fuel consumption formula
    I'm not the only one who's using this kind of oil... no problem at all....
    Nov 2003
    the 5w or 0w shoudln't really make much of a difference
    ok na yan for your purposes.
    Thanks speedyfix.
    Aug 2005
    Mobil 1 0-40 ang gamit ko since last yr to my 2001 SR REVO and I'll be using this one to my new Getz on its 1k PMS. You can feel the difference sa hatak with smoother Idling on the engine. Well, baka pakiramdam ko lang na tumulin ang car ko pero tingin ko mas ok sya kesa dating langis ng TOYOTA.Dinadala ko lang every uwi ko dyan sa atin around P350/liter as per my conversion
    Aug 2004
    I think Toyota recommends it due to running problems they were having on their 1ZZ engine in the US due to the long change intervals (10k MILES sila doon... )... there should be no problem with 0w on their new close tolerance engines. It's not a JUST a money making scheme... it's also to protect the life of their new engines, which aren't proving as bulletproof as they'd hoped.
mobil 1 0w40
