Originally Posted by
the_possessed
makikipost lang with same issue.
blinking 4 wheel indicator problem.
- checked solenoid valve. ok naman. i removed it from the engine bay and clean it. put external power source and oks naman.. i tested it while engine is running, oks naman ang vacuum. so no problem sa solenoid.
- checked the actuator, if you changed from 2W to 4W and from 4W to 2W, I can feel na nagtotoggle while holding the boots. So my guess is ok din ang actuator. Anybody tried this? I wonder kung ung toggle ay parang push and pull or dapat parang hydraulic na swabe ang pag in and out ng bushing?
- checked the hose, pero wala namang crack.
- what else could be wrong? i still get the blinking lights.. could it be the freewheel engage switch?
- anybody tried removing the freewheel clutch assembly?
- whats causing the indicator to blink? is there a sensor somewhere?
thanks!
