Results 11 to 20 of 27
- Aug 2005
- 18
August 15th, 2005 10:15 AM #11blinking 4wd indicator may not mean the system is engaged could be something else, do you have enough gear oil in the transfer case? grounded wires will cause blinking also and loose indicator light in your instrument panel may cause also light to blink.
- Nov 2004
- 115
August 15th, 2005 10:49 AM #12jeegogs : I'll try what you suggest.. dapat ba naka 4x4 pag atras?
sonny: yes I have enough gear oil.. here's what actually happens.
from 2W I switched to 4WD.. the indicator light of the front wheel and central lock blinks while the rear wheel light stays. When I switched back to 2WD and try to drive the car forward, It feels like somethings is stopping the car, parang naka handbrake.. then I can hear a "clank" sound as the wheel slowly revolves and eventually everything becomes normal..
- Nov 2004
- 115
August 15th, 2005 12:36 PM #14dati ayos ito eh.. tapos bigla nalang nag ka ganito nung pinapalitan ng clutch disc and etc.. i don't know if they mess it up.. since then hindi ko na napaayos.. mag 1 year na siguro.. ngayon lang ako nag ka time..
- Jul 2005
- 83
August 15th, 2005 07:10 PM #15Originally Posted by the_possessed
kung parang may pumipigil nga especially pag niliko mo un steering pag abante mo,malamang stuck up nga un auto hub sa front wheels mo.mawawala yan pag atras mo mga 10-15 meters using 2W only.
kaya lang babalik nanaman yan pag engage mo ng 4x4,something wrong with the system kaya pa check mo nalang.(adjustments)
- 135
September 18th, 2005 02:29 PM #16ano pala contact number ni j Atutubo?
gusto ko sana paayos 4 wheel drive blinking indicator ko. and yung compass ko rin natanggal sa loob ehsaan po banda location niya?
September 18th, 2005 08:19 PM #17
It's been posted a couple of times before, use tsikot search engine. Just below the navigation bar. ;)
September 18th, 2005 08:41 PM #18
this may be an off topic..sir, pasabit na din sa thread mo,ha?
the 4wd on my liteace wont engage...switch lang ang pag-engage and lock the manual hubs...pero, pag pinipindot ko ung switch, di umiilaw ung indicator at di nag-eengage ung 4wd..
ask ko lang may sariling line/relay ang motor(i assume may electric motor ito)...sorry, nasanay ko kasi sa delica na may cable...mga 4wd toyota owners, pls help ha?
thanx!
- 135
September 19th, 2005 02:45 PM #19nahanap ko na number niya, thanks! mali hinahanap ko atutubo. atotubo pala. =)
ano pala effect nung sirang solenoid besides blinking indiocators?
may harm ba?
September 19th, 2005 10:22 PM #20
It can potentially harm the system if you put it in 2H. Keep it in 4H while the system is still faulty.
The Pajero uses a fail safe 4wd system. Meaning if something fails, it will always revert to 4x4. Unlike other vehicles where you 'switch on' the 4x4, on a Pajero, you actually switch it off. The default is 4x4 and it just forces itself to 4x2 by using vacum pressure.
Nagblink din ang indicators ko a few days ago, so naka 4H muna ko.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
