Page 6 of 6 FirstFirst ... 23456
Results 51 to 60 of 60
    Aug 2012
    #51
    Thank you. It would be great if you can post the link so that others who might be interested can also take a look.
    Because links may change, just type "Car Anti-slip Block" or "Tire Chock" or "Car Stop Block" in the search box. It will show you the correct item.
    Example of Tire Chock/Block:
    Quote Originally Posted by khun22 View Post
    Mall car accessories shops meaning po ba yung mga tipong ace hardware or handyman na may automotive section? Ang nakikita ko lang po kasi dun is yung pula na jacklift yung mga tig 1k-2k depende po ata sa weight capacity. Okay na po ba yun for home use, my car is a honda city 2016 which is around 1600kg po.
    pwede na yun
    di naman kailangan ung katulad ng ginagamit ng tire shops
    malaki at mabigat yun
    but this is a nice jack
    it's just a bit too much kung pang personal use lang
    minsan lang gagamitin
    Jun 2012
    #54
    If cannot rely sa hand brake, lagay sa primera pag manual
    Sent from my SM-A9000 using Tapatalk
    Jan 2016
    #55
    Bring your own jack stand to place under the jack point or in my case, i place my scissor jack, paniguro lang...
    Jun 2017
    #56
    Ang dami ko na namiss na replies hahaha, I am also planning to get a jack stand especially pag natuto nako mag kalikot sa oto ko para pag may aayusin is safe pag inangat kaso ang problema ko lang is wala daw front jacking point ang city? totoo ba ito? Sa civic fd kasi meron may nakita ako na video sa yt na pinakita lahat ng jacking point ng civic fd nung chineck ko sa city ko parang wala ngang front jacking point?
    Whoa! Hold on my friend. Do not use a garage jack as you would with the scissors jack that came with the car. First, the garage jack average height ranges around 17 - 17 1/2 inches from the finished floorline whereas the car's jack only raise to around 10 inches. Second, do not use a garage jack at any one corner of the car specially unibody/unitized body. The car's frame can twist so much that might crack the windshield or rear window or delaminate it away from the windshield/window frame causing water leaks when it rains. If you watched this from Scotty Kilmer, don't do it for reasons just stated.
    Diko pa rin magets to can someone elaborate or explain this in layman's term? ang pag kakaintindi ko wag gamitan ng ibang jacking tool other than the scissor jack na kasama sa sasakyan nung binili pag ijajack up sa side jacking points? tama po ba ang pagkakaintindi ko?
    #57
    Quote Originally Posted by red_one View Post
    You can buy anti-slip tire chocks/blocks online like in Lazada.
    Sent from my ASUS_X00DDA using Tapatalk
    or you can drop by a lumberyard and ask for a pair of 4 x 4's, about 12 inches long. then trim to a roughly triangular cross section.
    Dec 2007
    #58
    Dati may mga foldable na ganyan. Sa surplus stores or yard madami dati.
    Sent from my ASUS_Z012D using Tapatalk
    May 2008
    #59
    may alam ba kayong repair shop ng floor jack dito sa Quezon/Marikina City area. tumutulo yung akin sa cylinder shaft. nagkakalat ng langis. sayang naman.
    #60
    Quote Originally Posted by goldrat View Post
    change o rings lang yan pwede DIY.
Where to buy jack/lift?
