Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    May 2005
    Which is the correct way of closing a vehicle's hood, by
    1) Lowering the hood slowly until the hook will latch on and press down to lock.
    or
    2) From a height of 300mm or less drop the hood. This would lock the hood already.
    I use method#1 but when I use this method, I noticed the portion of the hood where I press down on to lock, has some small dents.
    I'am thinking maybe if I can use method#2 to avoid the dents, but I dont know if I drop the hood like that, it might destroy the lock(hook)mechanism inside.
    So, which method does the least or no damage at all? I dont want the dents neither do I want to inadvertently destroy the hood locking mechanism.
    Pls help.
    May 2005
    the owners manual of my car suggests raising it about a foot then dropping it
    me i drop it from a level of around 4-6 inches coz method 1 doesn't work for me
    i drop my hood (roughly between 5-12 inches)...the lock is sturdy, you can't break it. Dati I use number 1 method, I also see dents...so I changed style
    Jun 2004
    I drop my hood from about 6 inches, thats what my manual states.
    Mar 2005
    6-8 inches is my memo to all the service shops i managed
    Mar 2005
    RTFM
    with some cars the manual suggests dropping. with others pushing down with the palm is suggested.
    probably depends on the design of the latches and reinforcements
    what i do is leave at least around a foot tapos bibitawan kona and let it lock by itself
    Aug 2004
    Never press on it... futresang ineng... I have dents on my hood already because I'm not the only driver. (okay, I'll admit to causing just one of them :lol: )... automotive sheet metal is pretty soft in the area around the latch. I always drop it about 1 foot. Scary, but it works.
    Dec 2003
    ito ang ginagawa ko kase may hood pins pa ako medyo hindi naka align yun hood ng fronte ko eh..
    I drop it from 5 to 8 inches.
    Mga honda reasonable height and drop.
    Mga toyota push down to lock
    Based on experience lang.
    May 2004
    method 2
    May 2005
    Thanks for the replies! Nice to know the clear majority secure their hoods by "dropping" (method#2) without any adverse effects on the hood locking mechanism. :D
    Feb 2005
    ako drop din lang, kahit ansama pakinggan pag binbitawan mo un hood.hehe
    Drop the hood. That is how it is explicitly stated on most new motor vehicle owner's manuals.
    Aug 2004
    #2. its really the right way I think.
    Aug 2005
    Drop it from a certain distance enough to lock it, about one foot.
    Aug 2005
    hmm.. i always do method 1. better change to method 2. thanks for the tip!!
    Sep 2005
    dropping from about 30 cm works in my xuvi. i never push coz it will never lock. unless gusto kong mayupi yong hood ko.
How to close the hood properly
