Results 1 to 7 of 7
- Sep 2004
- 15
June 13th, 2005 01:21 PM #1i was wondering if you guys can help me with my problem. i was trying to replace my 99 honda civic stereo in my 1987 honda accord with a pioneer head unit. i removed the civic stereo & plug in the pioneer head unit. it did not turn on. i checked all the wire connections & all connections are good. thinking that my pioneer head unit was bad, i plugged the civic stereo back but it did not turn on as well. i tightened all the connections but nothing happened. when i plugged in my stock cassette radio, it worked fine. what do you guys is the problem? did i blow a fuse? all electronic equipment in the car is working. i appreciate anyone who could help me on this weird problem.
June 13th, 2005 02:23 PM #3
Originally Posted by eliteimage
check your unit power diagrams
check fuse
try connecting all 12 volts +(ignition ,power antenna, power etc.. ,)all positive power polar wires to your + battery(directly),then ground - ..
do not include the positive speaker polar and negative.
no power, unit maybe defective
if unit turns on, you need to recheck all your connection,,,
no luck , bring your vehicle to the nearest car service stereo centerLast edited by axelangel007; June 13th, 2005 at 02:27 PM.
- Sep 2004
- 15
June 13th, 2005 03:49 PM #4Originally Posted by axelangel007
June 13th, 2005 11:27 PM #6
baka may lock ang hu mo.yung hu na tinanggal namin from our old l300 ganun.di ggana unless unlocked siya.security features.we never bothered to unlock it though.so i dunno how.go to pioneer centers nalang
- Sep 2004
- 15
June 14th, 2005 01:51 PM #7thanks for all your opinions! it turns out that i blew the clock/ecu fuse. i replaced it & it works now.
I just bought an OEM Honda washer fluid. Ok Lang kaya ihalo sa naka mix na filtered + distilled ...
Windshield Washer Fluids Talk
