Results 1 to 7 of 7
Threaded View
    Apr 2005
    Quote Originally Posted by eliteimage
    . i checked all the wire connections & all connections are good. thinking that my pioneer head unit was bad, i plugged the civic stereo back but it did not turn on as well. i tightened all the connections but nothing happened. when i plugged in my stock cassette radio, it worked fine.
    check your unit power diagrams
    check fuse
    try connecting all 12 volts +(ignition ,power antenna, power etc.. ,)all positive power polar wires to your + battery(directly),then ground - ..
    do not include the positive speaker polar and negative.
    no power, unit maybe defective
    if unit turns on, you need to recheck all your connection,,,
    no luck , bring your vehicle to the nearest car service stereo center
Weird Stereo Installation Problem -Pls. help
