Results 11 to 20 of 27
October 22nd, 2006 02:17 PM #11
A full box heat shield costs a lot. Mine will cost between 4k to 7k. I'm currently using a 500 peso Simota Heat shield.
K&N filters are supposed to help consumption, but I can't tell. My current consumption hovers between 8.6 and 9.6 km/l (mixed city/highway/hataw/traffic), but I've got other mods, so I can't be sure what does what.
October 22nd, 2006 03:12 PM #13
On small displacement cars? Increase displacement by using a stroker kit, but it doesn't give much, unless you do a 2.0 bottom end swap... :evil:
A longer intake tract gives more torque at the expense of horsepower...
The only sure way to increase torque on a B16 is with a turbo or supercharger.
RE: HP versus torque... True, HP is merely a mathematical calculation of torque and rpms, but HP really matters in racing.
Torque - it's that kick in your back as you launch the car.
HP - it's what gets you to the finish line.
The old adage: HP sells cars, torque wins races isn't strictly true... I've never seen a truck win a stock car race... What is true, though, is that good HP without good torque will severely hurt performance numbers. As with the SiR, there are cars that match it in the quarter mile at a similar weight and less horsepower simply because they have more torque.
October 22nd, 2006 03:22 PM #14
hhmm.. :seesaw:
gusto ko kasi mag palit ng b18!
anu ba sa tingin nyo mas maganda ko gawin b18b na block(non-vtec) para LS set-up or b18c5 na block! hinde ko alam kung alin sa dalawa mas maganda! kasi kung internals lang nila ang mag kaiba eh pag nag stroker kit ako mapapalitan din lahat ng internals nila! at presyo kasi ng b18b is 1/4 of b18c5
October 22nd, 2006 03:30 PM #15
Mahirap mag-block swap... you've got to find someone good at it, and if it's not well done, you could be looking at a high maintenance set-up.
If your original motor hasn't been compromised yet, and you're using it on the road, forget the block-swap, just save up for the B18.
You could, of course, go full exhaust and intake. With the right exhaust, you won't lose any torque. Tapos lightweight pulleys at flywheel, then cams... just don't get cams that are too aggressive, otherwise, say goodbye smooth idle, and hello big gas bills...
You just have to accept (for the meantime) that lunging torque just isn't the SiR's calling... same as I have to accept that I can't hit 160 hp with my stock muffler (aggghhh... the dyno!)
October 22nd, 2006 03:56 PM #16
kung mechanic lang pag uusapan wala ako problem sa mechamic sa h3 ko nag papagawa eh!
anu kaya
b18b:seesaw:b18c5
October 22nd, 2006 04:34 PM #17
Neither... K20... :evil: ...kaya lang, sobrang mahal pa...
October 22nd, 2006 04:50 PM #18
exclude the supercharger, a b16 with upgraded cams and tuned matches a b16 with a stock b16 with JRSC...
hp = [torque x rpm ] / 5252, it is a mathematical calculation
turbo s14 Silvia vs ITR The ITR is pushing 200 HP and roughly 140 tq only... I don't know of any car with about the same HP number but has more torque that could kick a Type R in stock for stock form...
October 22nd, 2006 05:04 PM #20
Mamar, I think you should hang-out at Honda-Tech if you really wanna learn about your car, but there're are mad haters in Honda-Tech that you might not be able to handle... However, Team-Integra.Net is also there, but you have to be patience during your first few weeks of posts, there isn't a site as strictive as T-I, I'm telling you, there's a T-I member who hits 12.XX in the quarter mile with an LS, non-vetec setup... I forgot his username, it was a long time ago when I was still hanging around there... GL
you don't buy a bike kasi may extra savings ka from somewhere... just buy a bike. explain later...
All New Toyota Corolla Cross
