Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 90
    Mar 2017
    #41
    There's a big chance it'll be missing after a few weeks.[emoji3]
    Sent from my SM-T705 using Tapatalk
    I'll probably do what bro Wh1stl3r does, remove them if I'm going someplace na medyo alanganin hehehe
    Feb 2015
    #42
    Quote Originally Posted by geraldalcos View Post
    Hello, baka OT. Pero ask ko lang, pano ko malalaman correct tire pressure nung auto ko, Lancer 97 size 205/45/17?
    Curious ako kung ano yung standard/recommended? Nung nagpalit kasi ako ng gulong, sabi saken sa shop 30 daw and yun yung sinusunod ko ngayon. And weekly ako kung magpaghangin sa mga gas station, kasi iba iba na pressure ng gulong after ilang days/week. Normal ba yun? Kaya minsan tinataasan ko ng mga 2-3 psi pahangin para medyo tumagal. hehe
    Ask ko na din if kunwari nagpalit ako ng tire size, same pa din ba dapat pressure nya?
    PS: newbie car owner pa lang ako and 2nd hand yung car and I didnt bother to ask the first owner kung ano PSI nya sa gulong hehe
    Thanks!
    It should be 35 psi cold inflation pressure. I would not trust the gas station boys or their inflator. Buy a digital tire inflator with auto-off feature. Besides, you are in warm inflation pressure by the time you reached the gas station. This means the pressure is offset by 1 to 4 psi. E.g. You are inflating at the gas station at warm 30 but it's cold 26.
    Your tire should lose about 1 psi per month normally.
    #43
    I've wanted to volunteer to make an announcement/reminder on the church's PA system re: the gitgitan and valve cap theft but the wife gives me dagger looks hehe.
    Sa inis, when we go to church we just take the car without valve caps.
    Grabe naman mga iyan, nagsisimba na mga tao, pinipitik pa rin ang valve caps.... 🤔
    Iyang gitgitan sa paglabas, talamak na problema na iyan. Para bang pag nasa harap na ng manibela, nasasapian bigla ng da-moon-you..... 😂
    #44
    Tingin ko sa mga naggigitgitan sa paglabas napilitan lang magsimba.
    Nov 2017
    #45
    Tanong nagsimba ba o pakita tao lang [emoji28]
    Sep 2018
    #46
    My rear right tire is consistently loosing its pressure. Everytime i go to gas station to inflate, the 3 other tires looks fine, ranging from 29 to 31 psi. The rear right tire pressure sits below 20 psi. what do you think could possibly wrong? the rubber or the valve?
    the front rubbers have been replaced but not yet the rear. anyone experienced this before? thanks.
    Mar 2018
    #47
    Quote Originally Posted by reymund View Post
    Just a simple case of slow leak. You can have it checked on the nearest vulcanizing shop you know.
    Sep 2018
    #48
    Thanks! Will do.
    Sent from my SM-A710F using Tapatalk
    #49
    you have a slow leak, po.
    have the tire checked at a good tire shop. and don't take "there's no leak" for an answer.
    the last time it happened to me, the leak was at the base of the pito. replacing the pito fixed my problem.
    the other time, it was a pakong bakya that had sunk in, making the head invisible.
    Sep 2018
    #50
    Thanks, doc for the advice.
    Nov 2017
    #51
    DriveGuard Run-Flat Tire by Bridgestone - YouTube
    Nice [emoji16]
    the valve can be easily checked with soap and water...
    if its not the valve.. there could be a nail or sharp object embedded on the tire. visit a shop to get a patch
    Feb 2005
    #53
    or may bengkong na yung lip ng mags mo like what happened to my mags nung binuhusan ng water with soap yung pito hindi bumula pero nung binuhusan yung lip dun na bumula ng husto dun pala sumisingaw although napaka konti ng singaw the tire loses about 1-2 psi every 4 days, kaya ang ginagawa ko every friday top up ng hangin and then on monday before going to work top up ulet.
    Quote Originally Posted by box_type View Post
    Usually nangyayari yan yun mga kinakabig na hook ng mga bulok na nag alingment/camber or naiihian ng aso nasisira talaga yun rubber doon sa lip ng mags.
    Feb 2014
    #55
    yeah check all around the bead for leaks. there might be corrosion on the rim which prevents good sealing. also most tire shops don't use the proper bead lubricant while installing
    Dec 2018
    #56
    Quote Originally Posted by red_one View Post
    This is the 12V AC-DC car power supply that I use. Max 10A or 120W. I do not need to turn on the car engine. I just plug this to AC outlet. It is universal voltage so can plug into 100-240V AC.
    Sir san mo po nabili to?
    Sent from my SM-J730G using Tapatalk
    Dec 2018
    #57
    Quote Originally Posted by ac3buddy View Post
    Okay na pla sir. Saw your reply on previous queries
    #58
    Quote Originally Posted by maxpedition View Post
    I remember the Parish (?) Priest of St. Joseph Church in Baguio directing traffic after the 5pm mass.... Behaved ang mga drivers...😉😉😉
    #59
    I have a similar one ....
    I have a 12V power supply and I just connected a cigarette lighter outlet...
    Jul 2019
    #60
    Hi folks,
    I have a question regarding tire pressure gauge accuracy.
    I'm contemplating to buy a tire pressure gauge and I saw one in Blade Auto Center, its brand is OMP with accuracy of +/-1.
    What does +/-1 accuracy mean? Is that accuracy good?
    Many Thanks.
Tyre pressure
