It should be 35 psi cold inflation pressure. I would not trust the gas station boys or their inflator. Buy a digital tire inflator with auto-off feature. Besides, you are in warm inflation pressure by the time you reached the gas station. This means the pressure is offset by 1 to 4 psi. E.g. You are inflating at the gas station at warm 30 but it's cold 26.
Your tire should lose about 1 psi per month normally.
My rear right tire is consistently loosing its pressure. Everytime i go to gas station to inflate, the 3 other tires looks fine, ranging from 29 to 31 psi. The rear right tire pressure sits below 20 psi. what do you think could possibly wrong? the rubber or the valve?
the front rubbers have been replaced but not yet the rear. anyone experienced this before? thanks.
you have a slow leak, po.
have the tire checked at a good tire shop. and don't take "there's no leak" for an answer.
the last time it happened to me, the leak was at the base of the pito. replacing the pito fixed my problem.
the other time, it was a pakong bakya that had sunk in, making the head invisible.
DriveGuard Run-Flat Tire by Bridgestone - YouTube
Nice [emoji16]
or may bengkong na yung lip ng mags mo like what happened to my mags nung binuhusan ng water with soap yung pito hindi bumula pero nung binuhusan yung lip dun na bumula ng husto dun pala sumisingaw although napaka konti ng singaw the tire loses about 1-2 psi every 4 days, kaya ang ginagawa ko every friday top up ng hangin and then on monday before going to work top up ulet.
yeah check all around the bead for leaks. there might be corrosion on the rim which prevents good sealing. also most tire shops don't use the proper bead lubricant while installing![]()
Hi folks,
I have a question regarding tire pressure gauge accuracy.
I'm contemplating to buy a tire pressure gauge and I saw one in Blade Auto Center, its brand is OMP with accuracy of +/-1.
What does +/-1 accuracy mean? Is that accuracy good?
Many Thanks.
