Results 1 to 10 of 15
February 14th, 2008 12:07 AM #1
Mga Ka Tsikot very usefull po ito sa mga may sasakyan
Please see attached file
February 14th, 2008 01:33 AM #2
ei donski tnx...for sharing...in a couple of months m about to replace tires..
nice find...
February 14th, 2008 01:59 AM #3
Dre,
Ty sa info, schedule ko na rin magpalit ng gulong next month. And as I checked my tyres, ok naman sya sa DOM, although nung binili namin di ako aware sa criteria. Thanks!
November 2nd, 2020 12:31 PM #5
About tyres...
Palagi kong napapanood/napapansin sa car reviews na "road noise probably due to econo tyres"
If bibili ako ng bagong tyres for my car, paano ko malalaman na "econo" yung binibili ko?
November 2nd, 2020 12:56 PM #6
Don’t worry too much about it. There are good tires at a decent & affordable price. In fact, there are more expensive sport tires that are noisy too.
If you want decent tires on a budget, check out any of the Indonesian brands - GT, Achilles, Accelera, Neuton.
- 54,205
November 2nd, 2020 12:59 PM #7
November 2nd, 2020 01:26 PM #8
Econo-tires are tires designed for long mileage so they typically have harder rubber that wears down more slowly.
Goodyear Duraplus, Michelin Energy XM2+, Dunlop Enasave - the name typicay hints at economy rather than grip or handling.
I've written about this extensively here:
Finding the Best Tire for You
November 2nd, 2020 01:58 PM #9
Just to add, a good place to start is the tread pattern. If it is advertised as a quiet or touring tire, it will most likely be quieter. Touring tires usually start from rim sizes 15 and up.
November 2nd, 2020 01:59 PM #10
Econo? I dont think tyre manufacturers used this phrase. They used "eco" or maybe economical? Im not sure.
"Budget tires" is more of a generalizarion that they are more affordable.
Older small cars had alot of road noise because lesser insulation in the wheel wells.
Low rolling resistance tires with low tyre pressures will be noisy.
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
