Originally Posted by
happy_gilmore
hehehe bro. mukhang minalas ka sa casa ah.
for one, ang daling baklasin ng speedo assembly. had done it in less than 15 minutes.
pangalawa. i would suggest that you try to consult other reputable shops for the timing belt. ang timing belt kasi, may look new, but in reality, nawawala na yung pagiging pliant and stretchability ng goma. also, there might be small cracks inside the belt which can affect the performance of the belt, and might cause big damage in the future. if you have time, try to bring it to speedyfix. (dito ata sa may crame ang shop nya diba?)
pag nacheck na yung tb, then that will be the time you can validate if your speedo/odo has been tampered with. mas malaking issue yung TB eh. if it has been tampered with, then definitely, wala na tayong magagawa dyan. pag ok pa yung TB, then suspect a defective sensor, which you can deal with later.
one more question. ngayon, pag tumatakbo ka, ano nangyayari sa ODO? tumatakbo naman sya ng maayos? nag rereflect ba ng correct distance or something?
