Results 1 to 20 of 45
    Aug 2006
    Speedo sensors are usually throw away items. They are rarely serviceable. Plugging a new one in on a Pajero is a 10 minute affair. The sensor itself cost close to Php5k at the dealer. Around Php2,500 in Banawe (BestColt).
    Hi Guys,
    Just had my 97 EL lancer checked sa casa ( Mitsu Cavite ) para ma-check yung odometer kung ano naging problema....Hindi ako satisfied sa nangyaring check-up.
    Bali tiningnan lang nung parang visor yung reading sa instrument panel and sinabi na malamang natampered na daw iyun ( alam agad ? ), Binuksan nila yung hood and sinilip lang yung makina at kung san nakakabit yung sensor ( sabi ko kasi na baka yung sensor yung may problema ), sinilip lang tapus sabi nya na hindi daw sila nagche-check ng ganun ( electrical system ) and kailangan daw na baklasin pa yung assembly dun pati yung sa instrument panel and kung anu-ano pa..tapus tinanong ko kung magkano aabutin kapag pinalitan yung sensor and odometer kung sakaling defective,,ang sabi e...di daw sila nagpapalit nuon?????? e kung hindi puede sa inyo e ....SAAN PA KAYA PUEDE???? ( CASA NA NGA SILA DI BA???? )...
    Medyo mahinahon lang ako and di nagpahalatang inis..tapus tinanong ko nalang kung kaya ba nilang ma-determine kung talaga bang 188k na yung mileage nun just by looking on the car itself ( 77k lang kasi mileage nun nung makuha ko, tapus biglang naging 188k after 2 months na 50 kms a week ave. travel, di naman ako bumibyahe ng pagudpud to allen samar araw-araw kaya talagang katakataka ..)
    Tapus di pala puede ma-check sa pc yung mileage kasi di siya EFI, so tanong ko nalang kung napalitan na ba yung timing belt para magkaalaman na ( dapat alam nila kung napalitan na yun diba )..so binuksan nila yung cover tapus sinilip lang and sabi dapat na daw palitan TB tapus binalik agad belt cover, nakita ko yung belt mukhang maayos pa naman, may konting langis lang yung gilid ng cover tapus sabi dapat ko na daw palitan agad ...
    Tinanong ko ulit ng mahinahon kung napalitan na ba yung TB and di na sumagot yung visor ...
    So in short...di din ako nakakuha ng sagot sa CASA na iyon...wala kinahantungan pagpunta namin dun...
    Plano ko na nga lang dalhin sa mga talagang marunong mag-check sa mga ganitong klaseng problema..yung may makukuha namang result and magandang suggestion di yung panay palit lang alam i-reccomend ..Wala bang Mang Mario na puedeng puntahan pagdating sa ganitong case??? May alam kaya kayong odometer specialist na puedeng pagpagawaan???
    Help ulit
    Thanks
    Quote Originally Posted by ranken View Post
    Hi Guys,
    Help ulit
    Thanks
    hehehe bro. mukhang minalas ka sa casa ah.
    for one, ang daling baklasin ng speedo assembly. had done it in less than 15 minutes.
    pangalawa. i would suggest that you try to consult other reputable shops for the timing belt. ang timing belt kasi, may look new, but in reality, nawawala na yung pagiging pliant and stretchability ng goma. also, there might be small cracks inside the belt which can affect the performance of the belt, and might cause big damage in the future. if you have time, try to bring it to speedyfix. (dito ata sa may crame ang shop nya diba?)
    pag nacheck na yung tb, then that will be the time you can validate if your speedo/odo has been tampered with. mas malaking issue yung TB eh. if it has been tampered with, then definitely, wala na tayong magagawa dyan. pag ok pa yung TB, then suspect a defective sensor, which you can deal with later.
    one more question. ngayon, pag tumatakbo ka, ano nangyayari sa ODO? tumatakbo naman sya ng maayos? nag rereflect ba ng correct distance or something?
    Madali lang alisin ang instrument cluster. I used to take them out of the company cars dun sa pinagtatrabahuan ni baiskee. Kinukuha ko kasi yung 'green condom' ng bulbs. hehehe. I know it's bad, hindi ko na ginagawa ngayon.
    Aug 2006
    guilty! sir otep bkit po masama pag tinanggal yung rubber na cover ng bulb? madilim na po ksi yung sa instrument cluster ng van nmin kya nilinis q tpos tnanggal ko yung rubber na cover nung bulb. hehehehehe
    Aug 2006
    Quote Originally Posted by happy_gilmore View Post
    Thanks sa reply.
    Yup, medyo minalas nga kami dun sa CASA na yun..
    Actually my plan was to replace na lang din ASAP yung TB para nga makasigurado, di ko nga masyado maitakbo yung sasakyan ng malayuan dahil nga sa condition nya..
    Gumagana naman yung odometer kapag ginagamit namin sasakyan, kahit yung trip meter ok naman ( Nai-seset ko pa sa zero yung Trip meter) ..pero di ko lang talaga sure kung calibrated pa yun, baka kasi may discrepancy na yung reading nya..
    Ask ko lang kung may mabibilhang digital odometer sa banaue? any ideas with regards to the cost? May nagpapalit kaya nun sa Banaue?
    Nakakairita lang kasing tingnan yung Metro lalo na't yung 188k mileage yung nakabungad agad ..
    Thanks sa reply.
    ah ok....
    i've checked your problem...
    at 188,000 kms/9 years na yung car = 20,888 kms/year
    20,888 kms/year/12 months=1740.66 kms/month
    1740.66 kms/month/30 days=58.02 kms/day
    at 58.02 kms/day, its quite logical. i average around 60 kms/day from Makati-Las Pinas and vice-versa.
    tingin ko nga tampered odo mo...
    opinion ko lang po ito ha?
    on your other question: may nabibiling ganyan sa banawe.
    yung naiirita ka na 188,000 kms agad nakalitaw. switch mo na lang. gawin mo na lang na yung "TRIP" meter ang nakadisplay. hehehehe.
    Aug 2006
    ah ok....
    Thanks sir sa computation, maaring ganun na nga yung naitakbo ng sasakyan, Hinanap ko nga din yung dating may-ari ( para tanungin sa history ng sasakyan ) e nagresign na pla dun sa dati nyang work..ayun at nasa dubai na pala..tapus nalaman ko na taga-santa rosa laguna siya and dyan sa Paranaque nagwowork..( malamang sa hindi ganun nga talaga ave. mileage nya )...
    Hehe..thanks sa advice sir ha..actually ganun na nga lang din talaga ginagawa ko minsan..isine-set ko na lang din sa trip meter yung indicator para zero ang lumalabas...mind over matter..
Tampered kaya Odometer ko???
