Results 11 to 18 of 18
November 19th, 2007 02:19 PM #11
Sirs,
Question rin po, when I had my vehicle serviced sa talyer, the mechanic told me that there is already a small "play" sa stabilizer bar ko. What are the effects of this "play" sa driving experience ko? Although sabi ng mekaniko there is still no worries pa. Thanks and God bless.
November 19th, 2007 03:49 PM #12
the oem stab link is expensive. but there are also replacement stab link which goes more or less P2000/piece in binondo.... its fairly easy to replace and any suspension shop can do it for you....
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 20th, 2007 11:42 PM #13it will normally manifest itself in noise over small bumps. kung wala pa naman then it should be ok pa.
- Nov 2003
- 3,848
- Nov 2005
- 368
December 6th, 2007 06:13 AM #17pasensiya na at ngayon lang nakapag-update... I brought the van to another service center - ang gustong palitan : shocks in both front tires... atsaka struts at the rear...
tapos, I called the Dodge dealer and asked them again what they wanted to replace - sway bar linksand bushings.... pasensiya na kayo at di ko naklaro ang problema ng van...
ngayon mas naguguluhan ako... alin ang dapat palitan?... ang na-eexperience ko kasi pag dina-drive eh maalog at katok ang gulong sa harap pag- dumadaan sa konting lubak...
ano ba ang pagkakaiba ng links, bushings at shocks and struts... paki-explain naman po....
- Nov 2003
- 3,848
December 9th, 2007 08:42 PM #18shocks and struts are probably the same thing. easy to check the sway bar links naman. just unconnect them and test drive. if the noise is gone then replace them.
sa shocks naman you have to uninstall them to see if ok sila or not.
The dissolvable tablet washer fluid seems to test out great. Very cheap and does appear to clean...
Windshield Washer Fluids Talk
