Results 1 to 18 of 18
    Sir speedy,
    Like kalampag na noise?
    Nov 2003
    yup kalampag and a knocking sound.
    Okay, Thanks sir speedy . .
    pasensiya na at ngayon lang nakapag-update... I brought the van to another service center - ang gustong palitan : shocks in both front tires... atsaka struts at the rear...
    tapos, I called the Dodge dealer and asked them again what they wanted to replace - sway bar links and bushings.... pasensiya na kayo at di ko naklaro ang problema ng van...
    ngayon mas naguguluhan ako... alin ang dapat palitan?... ang na-eexperience ko kasi pag dina-drive eh maalog at katok ang gulong sa harap pag- dumadaan sa konting lubak...
    ano ba ang pagkakaiba ng links, bushings at shocks and struts... paki-explain naman po....
    Nov 2003
    shocks and struts are probably the same thing. easy to check the sway bar links naman. just unconnect them and test drive. if the noise is gone then replace them.
    sa shocks naman you have to uninstall them to see if ok sila or not.
Sway Bar
