Results 11 to 20 of 32
February 20th, 2008 10:02 PM #11
check mo nga sensors, abs, pad thickness sensor baka may sumasabit sa rotor. also as XTO said yun axle bearings mo.
February 21st, 2008 12:06 PM #12
Hmmmm... sige boss afrasay. Napansin ko lang ito right after ko magpa reface ng rotor sa SpeedLab.
Thanks,
February 22nd, 2008 08:23 AM #13
ako nagkarun ng ganyan ingay nun nag palit ako ng all 4 disc rotors....hehehe.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 24th, 2008 12:06 PM #14have them check if the pad retaining clips were reinstalled properly. baka gumagasgas lang sila on the rotor. possible din may contact yung backing plate sa rotor.
March 3rd, 2008 06:32 PM #16
I had it checked again... they checked if everything was installed properly... oks naman. They just cleaned the braking linings - the squeaking sound diminished after the cleaning process (and the stopping power is now adequate).
The mechanic also rolled the vehicle (while it was in the lifter) with the front tires out... wala kaming marinig na squeaking sound... pero on the road may konti pa din.
March 4th, 2008 02:31 AM #17
Dapat kasi may load pag niliko yun tires. Need siguro lagyan ng brake paste yun pads. Ganyan din yun W124 ko. Pag nilinis palagyan ko ng brake paste.
March 4th, 2008 09:33 AM #18
Got it... thanks... pa-check ko na lang ulit siguro kapag nagpa oil change ako next month.
April 8th, 2008 04:21 PM #19
Argh... it's back! :cry2:
Gonna have it checked it again... kapag matagal naka park yung vehicle... minimal ung noise... pero kapag matagal nang ginamit and am parking/manuevering... rinig na rinig kapag nakabukas ang bintana. :seeth:
April 8th, 2008 05:00 PM #20
