try replacing your brake pads with ORIGINAL pads.. not those replacement pads... double piston ba calipers mo?? same thing happened to my kia carnival nag replace ako ng brake pads and reface ng rotors after two weeks may squeaking sound na nakakairita lalo na pag na sa side ka ng road nag bounce yung sound ang ingay....kahit lagyan ng kung ano ano chemical na anti-squeak may ingay pa din.. i carefully inspected yung pads eh slightly warped pala due to extreme force applied by dual piston brakes...then i used an ORIGINAL brake pad.. ayun nawala na squeaking sounds... hehehe also when installing yung caliper bolts (2 bolts holding the calipers in place) make sure na may grease na nakalagay sa loob to avoid naman yung clanking sound...
