Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    #21
    Quote Originally Posted by 1D4LV View Post
    pre....mukhang humihingi na ata ng kapalit si rav4 mo ah...
    Hahaha... hindi pa naman - 5 more years pa! Minor quirks lang naman (expected na naman at 110,000+ kilometers). :D
    Doesn't affect the steering or braking... nakaka-irita lang. :seeth:
    Jan 2008
    #22
    Quote Originally Posted by mazdamazda View Post
    try replacing your brake pads with ORIGINAL pads.. not those replacement pads... double piston ba calipers mo?? same thing happened to my kia carnival nag replace ako ng brake pads and reface ng rotors after two weeks may squeaking sound na nakakairita lalo na pag na sa side ka ng road nag bounce yung sound ang ingay....kahit lagyan ng kung ano ano chemical na anti-squeak may ingay pa din.. i carefully inspected yung pads eh slightly warped pala due to extreme force applied by dual piston brakes...then i used an ORIGINAL brake pad.. ayun nawala na squeaking sounds... hehehe also when installing yung caliper bolts (2 bolts holding the calipers in place) make sure na may grease na nakalagay sa loob to avoid naman yung clanking sound...
    Nov 2003
    #23
    if maparinig mo when you bring it back it might be easier to find the root cause
    #24
    speedy, will try to bring the car ASAP... just busy din kasi. mahirap marinig kapag maingay din kasi ang daan... maybe we can do a road test sa may gold loop in ortigas.
    yapoy, am using tanabe performance brake pads (thanks to it - a stray dog is alive - hehe)... am pretty sure it's not the culprit and will not warp... the squeaking noise (sa left side lang naman) came after i had my rotors refaced.
    there is no squeaking sound kapag na lubak or hard braking or whatever... kapag nag turn lang ako to the left... the tighter the turn the noisier it gets.
    __________________
    bigbigcar.com Review: Ford Everest XLS 2.5 TDCi 4x2
    #25
    Check the wheel bearing. I've had the same thing happen on two vehicles and it was the wheel bearing.
    #26
    I hope it isn't the wheel bearing... though I know a Rav4 owner who had a wheel bearing problem before and the symptoms was different.
    bigbigcar.com Review: Toyota Avanza 1.5G
    Nov 2003
    #27
    allright i'm out of the country din til the 24th so sakto timing ng pagkabusy mo. hehehe! seeya soon though!
    #28
    Symptoms aren't always the same. But if you have no noise when braking or hitting a bump then you can eliminate the brakes and suspension. Is it a high pitched squeaking sound? Does it only have the sound when you turn to the left and not the right? Does squeaking only come from one side and not the other? If it's yes to all three then it's your bearing.
    #29
    Bought the car again to Speedyfix's shop... they removed the brake pads and installed it. Then the problem magically went away after their head mechanic road tested it.
    Also tested it this morning in our office parking... wala na din.
    redorange, yup... what you mentioned is basically the symptoms. Though am not sure why it *disappeared* after speedyfix's mechanic inspected it.
    :headache:
    Nov 2003
    #30
    bro has it come back pa? it's really a weird problem. hehehe!
    #31
    So far so good... weird nga. :rofl:
    #32
    having the same problem with my Honda Sir 99.. brake pads lang ba? may squeaking sound when you turn hard right for me...
Squeaking Sound While Turning in a Tight Corner
