Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    Sep 2006
    Plan ko po magpalit ng "CV joint" assembly and if incase pati "Axel Shaft" on my Corolla 90.
    1. How much po ba yung replacement of the two items i've mentioned? Any idea po?
    2. Is it possible to replace only one side, for instance sa right side?
    3. What brand for replacement is best in quality, durability?
    4. How much po kaya aabutin on Labor?
    Right Side, since dun po yung may tumutunog pag malubak(Tipong mababaklas na yung buong sasakyan sa ingay ng manubela) Example po, pag dumaan ako coming from San Juan going to Araneta Ave. Pagpasok na pagpasok po kase ng A.Ave mejo malubak ayun, Nagpproduce na ingay Nanginginig na manubela and sound under the hood start to roar.
    But I was wondering kase na pagnaka aspalto yung kalsada and my mga lubak, hindi naman po nagpproduce ng sound sa manubela.
    Salamat po in advance
    Apr 2005
    replacement c.v.joint is 1850 per piece, nkn brand. labor 450/pc. i would recommend replacing both sides to save downtime.
    based on your symptoms mentioned, baka balljoints lang yan. CVJ sa pagliko tumutunog.
    replacement balljoint 650/pc.
    i just had my CVJ's replaced. my problem now is lumalagutok pa rin kahit going straight lang basta arangkada. sabi mekaniko, mawawala daw yun after some time. until lumapat mabuti new CVJs. sana nga.
    un sa akin cost almost 4thou both sides last monday lang....replacement CV joint + labor....kaya lang may maingay pag-mabagal pero pagmabilis naman nawawala...babalik ko nga para makita ulit .....
    Sep 2006
    Thanks sa mga reply. anyway, nagtanong ako sa my Celica along Araneta. Price is between that range. pero taga sa labor yung katabing BIG name shop. almost 1Thou+.
    Apr 2005
    it's been over a month now, lumalagutok pa rin new cv joints car ko when accelerating/arangkada. alin kaya problem, yung pagkagawa or ung new replacement cvj's?
    Jul 2003
    yung lagutok ay maaaring naggagaling sa inner cv joints. maaari kasing my play na yung "spline" na nakakabit sa transmission. napalitan mo din ba ang inner cv joint, both sides?
    May 2007
    Kung nagawa na nila noon ay may lagutok pa, maaring careless ang mechanico mong gumawa. Generally, e confirm mo ang damage kung yong balljoint lang ang sira o kaya may vent na ang halfshaft mo o di kaya hindi nilubricate ng maayos. Have them also check both, inner and outer joint.
    Sep 2005
    sakin may lagutok na pag naliko...pwede pa bang i-repacked yung CVJs ko?
    May 2007
    Quote Originally Posted by puroy View Post
    Better replace it than used the same one. CV joint is one of the most crucial mechanical parts of your car so its a lot wiser to replace besides may tama na yan. Remember, your mechanic must know the torque of your CV joint when he reassembled back in, too tight can damage the halfshaft, too loose will damage it too. If your not sure about your mechanic if he knows about this find out the torque lbs., of your car.
    Apr 2005
    Quote Originally Posted by tip_tipid View Post
    not yet, outer cvj lang.
    thanks tip & v6!
Replacing C.V. Joint
