Results 1 to 10 of 34
December 10th, 2007 01:44 AM #1
Plan ko po magpalit ng "CV joint" assembly and if incase pati "Axel Shaft" on my Corolla 90.
1. How much po ba yung replacement of the two items i've mentioned? Any idea po?
2. Is it possible to replace only one side, for instance sa right side?
3. What brand for replacement is best in quality, durability?
4. How much po kaya aabutin on Labor?
Right Side, since dun po yung may tumutunog pag malubak(Tipong mababaklas na yung buong sasakyan sa ingay ng manubela) Example po, pag dumaan ako coming from San Juan going to Araneta Ave. Pagpasok na pagpasok po kase ng A.Ave mejo malubak ayun, Nagpproduce na ingay Nanginginig na manubela and sound under the hood start to roar.
But I was wondering kase na pagnaka aspalto yung kalsada and my mga lubak, hindi naman po nagpproduce ng sound sa manubela.
Salamat po in advance
December 13th, 2007 02:05 PM #2
replacement c.v.joint is 1850 per piece, nkn brand. labor 450/pc. i would recommend replacing both sides to save downtime.
based on your symptoms mentioned, baka balljoints lang yan. CVJ sa pagliko tumutunog.
replacement balljoint 650/pc.
i just had my CVJ's replaced. my problem now is lumalagutok pa rin kahit going straight lang basta arangkada. sabi mekaniko, mawawala daw yun after some time. until lumapat mabuti new CVJs. sana nga.
- Jan 2007
- 137
December 13th, 2007 07:38 PM #3un sa akin cost almost 4thou both sides last monday lang....replacement CV joint + labor....kaya lang may maingay pag-mabagal pero pagmabilis naman nawawala...babalik ko nga para makita ulit .....
December 16th, 2007 12:53 AM #4
Thanks sa mga reply. anyway, nagtanong ako sa my Celica along Araneta. Price is between that range. pero taga sa labor yung katabing BIG name shop. almost 1Thou+.
January 10th, 2008 04:45 PM #5
it's been over a month now, lumalagutok pa rin new cv joints car ko when accelerating/arangkada. alin kaya problem, yung pagkagawa or ung new replacement cvj's?
- Jul 2003
- 573
January 10th, 2008 06:30 PM #6yung lagutok ay maaaring naggagaling sa inner cv joints. maaari kasing my play na yung "spline" na nakakabit sa transmission. napalitan mo din ba ang inner cv joint, both sides?
January 11th, 2008 02:33 AM #7
Kung nagawa na nila noon ay may lagutok pa, maaring careless ang mechanico mong gumawa. Generally, e confirm mo ang damage kung yong balljoint lang ang sira o kaya may vent na ang halfshaft mo o di kaya hindi nilubricate ng maayos. Have them also check both, inner and outer joint.
January 11th, 2008 03:22 AM #8
sakin may lagutok na pag naliko...pwede pa bang i-repacked yung CVJs ko?
January 11th, 2008 12:12 PM #9
Better replace it than used the same one. CV joint is one of the most crucial mechanical parts of your car so its a lot wiser to replace besides may tama na yan. Remember, your mechanic must know the torque of your CV joint when he reassembled back in, too tight can damage the halfshaft, too loose will damage it too. If your not sure about your mechanic if he knows about this find out the torque lbs., of your car.
January 11th, 2008 12:29 PM #10
Agreed. Di alam mismo nung tamaraw driver na commercial vehicle ang dala niya, regardless kung...
Toyota Tamaraw (Hilux Champ)
