Results 11 to 20 of 24
October 29th, 2006 10:16 AM #11
for me rebuilding engine is better than suplus.IF they build it right.
October 29th, 2006 06:09 PM #13
Mga peeps,
Can you give me shops that specializes in engine rebuilding that returns the engine back to specs as in good as new. What can you say about AER and where is it located? Hope you can enlighten me. Salamat.
October 29th, 2006 07:42 PM #14
alam ko ang AER nasa may manila, along quezon blvd somewhere between dapitan and laong-laan part ng quezon blvd.
October 29th, 2006 11:51 PM #16
4j,
Look for a machine shop that uses sunnen.It's the best out there.
October 29th, 2006 11:53 PM #17
Likod lang ng UST ang AER. Sa dulo ng Laon Laan makikita mo siya.
Katabi ng Fersal Apartelle.
October 30th, 2006 01:04 PM #18
re-sleeve, balik sa orig ang performance.
re-bore, slight increase in power, increase in consumption,
easily overheat unless upgrade to a bigger radiator, in short
malaki gastos.
* boeing, wayback in '88 inabot ng P25T 4K ko. ginto magpa
overhaul unless gusto mong ibalik sa orig ang engine mo. para
kasing bago.Last edited by XTO; October 30th, 2006 at 01:06 PM.
- Oct 2006
- 32
October 30th, 2006 09:53 PM #19mga sir salamat po, tanong ko lang kung pwede ba isang block lang ang iisleeve? yung may tama lang pwede ba yun?
October 30th, 2006 10:07 PM #20
pagkaalam ko rebore is good for gasoline engine but up to a certain degree while sleeve is mostly use for diesel engines.
