Before buying 4 new wheels, I need to try something. Pa redone ko yun plug (pasak) sa right vulganizing who use can use proper tools. So I guess he will push the existing ones inside, clean/remove the oil, and then use a new string rubber plug that is glued inside using the right tools as explained in:
How To Use A Tire Plug Kit The Right Way
Now the biggest question is, sino vulganizing shop or repair center na meron right tools or own complete kits like in Lazada
Who are competent enough to do it? You can dm me if you don't it mentioned here. Thanks.
