Results 1 to 10 of 13
- Nov 2002
- 103
November 12th, 2004 10:16 PM #1are springs of the same car brand interchangeable? for example, cefiro and sentra, civic and accord, pwede ba pagpalitin? kasi i want to lower the front of my cefiro by half inch lang. wala naman ganong lowering spring na .5 lang ang drop. maybe if i buy the OE front springs of sentra, then because of the heavier engine of the cefiro, mas malolower sha ng konti.
help please.
November 13th, 2004 10:10 AM #3
nope hindi sila interchangeable. ask fusrion R kung meron silang available na H&R OE drop (1") for your cefiro.
- Nov 2004
- 2
November 13th, 2004 12:12 PM #4di nga sya pwede interchange dude. springs are made specifically for a certain type of car.
- Nov 2002
- 103
November 13th, 2004 09:32 PM #5i see. thanks for the tips. anyway, pano ko madadrop ng .5 inch yung harap? walang springs na ganun kakonti yung drop e. pangit din daw putol at compress... pano kaya yan...
November 14th, 2004 12:43 AM #6
kuha ka na lang ng lowering.. about 1.5 inch lang naman yun... hinde naman ganun kababa pag para sa akin... hehehe..
November 14th, 2004 10:24 AM #7
Some can be interchanged but you will have to experiment.
Nissan Patrol GQ springs can fit some Pajero models.
GEN II Pajero coil springs can be put into GEN I Pajero's [with coil rear] for a bit of a lift.
Ika nga nila, if the shoe fits. hehehe.
November 14th, 2004 10:54 AM #8
You can get the lowering springs which will lowe your car about 1.5 inches... then add rubber "lifters" which will add 1 inch in ride height.
- Nov 2002
- 103
November 14th, 2004 03:04 PM #9wow possible pala e! so how do i compare different stock springs if they'll fit? sa top and bottom diameter lang ba yun?
Tsikot Member Rank 3
- Jul 2004
- 1,540
November 14th, 2004 03:39 PM #10ayos yang naisip ni ghosthunter ah... tama nga naman... less 1.5 inch then add 1.0 inch then you get a .5 inch drop!
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
