Results 11 to 20 of 35
December 23rd, 2007 04:44 AM #11
- Dec 2007
- 40
December 23rd, 2007 01:25 PM #12Yes. But different manufacturers designed their own scan tools for certain purposes...such as programming the modules, taking snapshots, etc....
- Dec 2007
- 40
December 26th, 2007 12:52 PM #15
madownload nga hehehe. Thanks sir jeff. My friend has an OBDII scanner hope this would enlighten us. .
December 26th, 2007 03:37 PM #16
sir ako meron ako nabili na OBDII meron din siya sofware na pang read ng codes type mo lang yun code lalabas na yun meaning.
- Dec 2007
- 40
December 27th, 2007 07:59 PM #17Ayos yun...
Important sa diagnostics, ay kailangan alam mo yung system description...tapos may schematic diagram ka at connector end views...
Important din na alam mo ang OHM's Law... and when diagnosing electronic parts, always check for Voltage drop... di na uso ang test light... Isa pang magandang weapon is yung Fluke Multimeter... Maganda yun lalo na sa intermittent problems, peak min/max, duty cylcle...
Standard naman yung OBD2 sa lahat... kaya kahit anong make.. yung principle ganun pa din...
God Bless!
December 27th, 2007 11:28 PM #18
mag add lang po ako regarding obd2 and generic scanner or code reader, although the dlc is standard sa lahat ng obd2 compliant vehicles possible din na hindi ma access ng isang scanner or reader since ang mga manufacturer ay free sa communication system na gamit nila kaya hindi lahat ng obd2 kayang basahin ng scanner or reader.unlike sa 2008 model (na imamarket sa us) common na ang communication protocol which is CAN
December 28th, 2007 12:14 AM #19
may bentang reader sa ebay. don't just know though if it can read all makes of obd2
- Dec 2007
- 40
December 29th, 2007 07:28 PM #20Yup... depende kasi sa communication line na gamit ng car makers...
Some uses UART, meron din Class 2 Serial Data.... Meron din na combination of both... Then yung mga latest ngayon is yung LAN... For the scan tool to communicate with the modules on the vehicle which understands UART, Class 2 serial data or Lan.. They need a gateway to translate the messages... Here comes CANdi...
Once, sa training.. i asked the instructor kung bakit di na lang gawing WIRELESS yung communication between modules.... para ma-eliminate na yung wiring problem, like short to voltage, short to ground or open circuit...
He just smiled at me and said, il reply that later... Up to now, wala pang reply...
What do you think???? Mas ok kaya pag Wireless LAN???
God Bless!
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
