Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Dec 2007
    Learn how your car's system works....
    I will follow this thread. keep up the good work sir.
    Dec 2007
    Part two is now served....
    "If you want to work with something... first you must know how does it works..."
    Sir,
    When or where do you use Tech1? How about Tech2?
    Dec 2007
    Tech1 was the first scan tool used by GM. Then came the Tech2. These are scan tools or diagnostic tools where you can connect to your vehicle's DLC (data Link Connector) for you to connect and communicate with your vehicle's different modules, such as below:
    1. ECM - Engine Control Module
    2. TCM - Transmission Control Moule
    3. PCM - Powertrain Control Module - combination of Engine and Transmission
    4. BCM - Body Control Module
    5. EBCM - Electronic Brake control Module
    6. EBTCM - Electronic Brake And Traction Control Module
    7. SDM - Sensing and Diagnostics Modules
    and so on... as of now... average of 24 modules meron ang mga GM Vehicles..
    And of course pati na rin yung ibang mga Car Makers..
    Dahil nga, ginagawang standard na yan ng SAE..
    Different car manufacturers uses different designs of scan tool..
    Im not sure pero sa toyota yata, intelligent tester yung tawag sa scan tool nila...
    Mack=Vmack prolink 9000DDR
    Detroit Diesel= DDEC DDR
    Cummins=Celect plus Intelect,Insite(inquire)
    Caterpillar=ECAP
    Dont know kung napalitan na sila.
    Thank you sir.
    Post pa po ako questions of topics i dont fully understand, if its ok?
    Dec 2007
    I will... At time being yang part 1 and 2 lang muna.... tatapusin ko lang yung iba.. Nasa work kasi ako ngayon...
    Yup yung Cummins Insight yung sa engine, pero laptop gamit dun...
    sa Cummins Power Generation naman Inpower.... laptop din...
    yung service info cd tawag dun Intercept.
    Pero ngayon gamit namin yung web-based na. QSOL (quickserv online) naman tawag dun..
    Sa GM naman,
    Tech 2 yung scan tool... yung programming software naman para sa mga modules ay TIS2000..... Tapos yung service Info ay eSI.
    Dec 2007
    POst ka lang ng mga questions.. ako din naman magtatanong din pag di ko naiintindihan....
    ang idea ko lang naman more on GM, Cummins, Scania, Kenworth...
    Zero ako pagdating sa Japanese.. although pareho yung principle, pero iba-ibang manufacturers, may iba-ibang design.. pero yung principles ganun pa din...
    Dec 2007
    Part 3 now is served...
    Any questions, comments, corrections... Dont hesitate posting it!!
    Dec 2007
    Last part... The part 4 is now served....
    This is general, since OBD2 is standard to all vehicles...
    This information is sufficient enough to understand how modules communicate with each other, what is the purpose of the sensor and how it affects the entire system... and how all of this are being interconnected to one another.
    The OBD2 was designed for one purpose, to save our environment...
    all of these electronic modules, sensors, computers... They are there in your vehicle to save mother earth from pollution.....
    Hope this will help you understand how your vehicle system works, analyze a little and you can have an idea to what part is faulty whenever you feel that something is wrong on your vehicle....
    Dec 2007
    Quote Originally Posted by sonjeffrey View Post
    Sir, iisa lang ang DLC para sa lahat ng mga OBD-II equipped vehicles. wether if its a American, Japanese or European car from 1997-present. also, you can use one OBD-II scanner for all vehicles, like those Snap-On MODIS, Scan Check.. etc.
    aite, peace.
    Dec 2007
    Yes. But different manufacturers designed their own scan tools for certain purposes...such as programming the modules, taking snapshots, etc....
    Dec 2003
    uy.. Thanks thanks.. ayus ito... copy ko sir ha.. save ko pala..
    Dec 2007
    No prob sir... sana makakatulong sa inyo..
    God Bless!!!
    madownload nga hehehe. Thanks sir jeff. My friend has an OBDII scanner hope this would enlighten us. .
    Sep 2006
    sir ako meron ako nabili na OBDII meron din siya sofware na pang read ng codes type mo lang yun code lalabas na yun meaning.
    Dec 2007
    Ayos yun...
    Important sa diagnostics, ay kailangan alam mo yung system description...tapos may schematic diagram ka at connector end views...
    Important din na alam mo ang OHM's Law... and when diagnosing electronic parts, always check for Voltage drop... di na uso ang test light... Isa pang magandang weapon is yung Fluke Multimeter... Maganda yun lalo na sa intermittent problems, peak min/max, duty cylcle...
    Standard naman yung OBD2 sa lahat... kaya kahit anong make.. yung principle ganun pa din...
    God Bless!
    mag add lang po ako regarding obd2 and generic scanner or code reader, although the dlc is standard sa lahat ng obd2 compliant vehicles possible din na hindi ma access ng isang scanner or reader since ang mga manufacturer ay free sa communication system na gamit nila kaya hindi lahat ng obd2 kayang basahin ng scanner or reader.unlike sa 2008 model (na imamarket sa us) common na ang communication protocol which is CAN
    may bentang reader sa ebay. don't just know though if it can read all makes of obd2
    Dec 2007
    Yup... depende kasi sa communication line na gamit ng car makers...
    Some uses UART, meron din Class 2 Serial Data.... Meron din na combination of both... Then yung mga latest ngayon is yung LAN... For the scan tool to communicate with the modules on the vehicle which understands UART, Class 2 serial data or Lan.. They need a gateway to translate the messages... Here comes CANdi...
    Once, sa training.. i asked the instructor kung bakit di na lang gawing WIRELESS yung communication between modules.... para ma-eliminate na yung wiring problem, like short to voltage, short to ground or open circuit...
    He just smiled at me and said, il reply that later... Up to now, wala pang reply...
    What do you think???? Mas ok kaya pag Wireless LAN???
    God Bless!
OBD2 (On-Board Diagnostics Generation 2)
