Results 31 to 40 of 85
April 30th, 2005 10:51 AM #33
Originally Posted by jardeus
Pano ba malaman kng original ang benta nito???
WBR,
- Apr 2005
- 6
April 30th, 2005 01:56 PM #34Sir, Mbt and Falken
What Is The Purpose Of This Forum/posting Of A Non-sence Msgs.? Is It Sharing Ideas Knowledge Right! Supalpal Agad Alam Nyo Ba Ang Sasabihin Ko. Eh Lahat Naman Nang Share Of What Is The Best For Our Car's Advertise Na Ba! Agad!.. . . Forget It! You Search Kung May Pareho Sa Sinabi Ko! . . . And Im Sorry Kung Mali Ako. sorry po!
Salamat For Your Wonderful Comment................... GoneLast edited by rallyrick; April 30th, 2005 at 02:08 PM.
April 30th, 2005 02:16 PM #35
Originally Posted by rallyrick
This sounds suspiciously like an advertising teaser...
April 30th, 2005 04:57 PM #37
Exchange of ideas is welcome on this message board but there are certain things you have to follow.
First, keep to the subject of the discussion.
Second, keeping good grammar and punctuation helps.
Third, rules are meant for something. read the rules and regulations.
Tsikot Member Rank 3
- Dec 2002
- 636
April 30th, 2005 06:37 PM #38Just some comments on oils mentioned:
1) Castrol Gtx is not a synthetic oil, their full synth is Formula RS
2) Top 1 synth oil- this is a semi-synthetic oil since the description on the can plus their website calls it a " Synthetic Blend".
3) Toyota synth oil- sourced from caltex
In looking for a synth oil for japan diesel engines, it's better to get one with at least an API rating of CF-4. Most synth oils for gas and diesel carry a rating of API SL/CF.
April 30th, 2005 06:46 PM #39
Synthetic for diesels:
http://www.mobil.com/USA-English/Lub...ac_1_5W-40.asp
April 30th, 2005 07:13 PM #40
baka yung ipo-post ni "rallyrick" is yung pang-clean ng engine.
this is the stuff na, during your oil change, drain 1/2 of your old oil, add the "super special cleaning additive," run the engine (idle) for 30 minutes, tapos drain everything. THEN replace the oil filter and put in new oil.
actually kerosene lang yang mga yan eh.)
pwede rin diesel fuel...
although if you want good detergency but not as harsh as kerosene (kasi yung kerosene it will remove all the carbon deposits, eh kung luma na makina mo baka magka-blowby pag natanggal lahat nung carbon) i've heard that a 1:3 blend of ATF (automatic transmission fluid) and ordinary mineral oil will give you most of the detergency characteristics of synthetic oil. remember that ATF is designed for an even more demanding application than engine oil (e.g. torque converter) and is more heat-resistant.
I just bought a 1 lb fire extinguisher for the car. Ang cute niya tingnan. 😁
Fire Extinguisher for Car: what brand and type...
