Results 1 to 10 of 23
- Apr 2004
- 1
April 14th, 2004 08:29 PM #1Yung Mazda 323F kasi namin malakas ang nginig kapag nasa N ang kambyo at yumayanig naman kapag nasa D.
Dinala namin sa Ford Balintawak para ipacheck at sinabi nilang nakita na yung problema. Dinala na namin sa kanila ito dati pero sandali lang tumakbo ng maayos yung sasakyan kaya nagdadalawang isip kami na sa kanila ipagawa ulit. Pero, at least ngayon, iba na yung mga piyesang plano nilang palitan...
1. throttle body, throttle hose and throttle position circuit
2. IAC valve
3. air cleaner hose
Baka naman may kilala kayong magaling na mekaniko at shop na may ganitong mga piyesa... Sigurado kasing mahal sa casa at para magkaroon din ng second opinion...
Pakipost din sana yung purpose ng bawat piyesa sa taas kung may nakakaalam...
Maraming salamat! :D
April 14th, 2004 09:57 PM #2
please refer to the related thread in the WORKSHOP forum.
btw, that problem is very common among 323s.
April 14th, 2004 10:09 PM #3
nginig? could be engine supports..ako rin e..parang namamasahe ako pag nasa D tapos nakabrake and aircon on..dalhin mo sa prince motors..bihasa yung sarvice manager dun sa mazda..
April 14th, 2004 11:47 PM #4
i have a very similar problem (nginig pag naka-aircon and braking) pero di naman namamatay yung engine.. 2.0L torque comes to the rescue! :P
i already replaced my rear and driver-side engine mounts, and the rear mount makes this annoying rattle (replacement kasi, liniha nila yung bolt hole para kumasya, but i think BS lang yun ng gumawa kasi di ko binili sa kanila yung mount). i was forced to get an orig mount for the driver side kasi walang replacement. :P mahal pa naman yun.
anyway, ayun nanginginig pa rin. i found na merong nagre-repair ng engine mount, pinapalitan yung rubber with polyurethane (naks! parang WRC car!) pero di ko mahanap saan ko tinambak yung lumang rear mount. :P
April 15th, 2004 05:49 AM #5
Nginig? Does the RPM drop?
I'n my case the curlpit, was the release bearing for the clutch all along.
When it finally broke affected parts were the clutch disk, pressure plate, melted bearing, flywheel bearing... the damage? 7,500.00
To think kulang lang yata sa grease??
- Apr 2004
- 7
June 11th, 2004 02:35 PM #6i have the same problem, may nginig cya pag release ng clutch and pag bukas ng aircon the rpm drops....what should i do? thanks!!!
- Apr 2004
- 7
June 18th, 2004 05:07 AM #9
New update from the "nginig" coming from the engine. I also went out of the car and pressed the hood down running in idle, tumahimik?! Went to the machanic and asked him to fasten them tighter and "voila!" totally wala nang nginig.
According to my friend his problem was the engine support.
Just giving you more things to check out to eliminate the irritating thing.
Monk-owned R53
