Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Apr 2004
    Yung Mazda 323F kasi namin malakas ang nginig kapag nasa N ang kambyo at yumayanig naman kapag nasa D.
    Dinala namin sa Ford Balintawak para ipacheck at sinabi nilang nakita na yung problema. Dinala na namin sa kanila ito dati pero sandali lang tumakbo ng maayos yung sasakyan kaya nagdadalawang isip kami na sa kanila ipagawa ulit. Pero, at least ngayon, iba na yung mga piyesang plano nilang palitan...
    1. throttle body, throttle hose and throttle position circuit
    2. IAC valve
    3. air cleaner hose
    Baka naman may kilala kayong magaling na mekaniko at shop na may ganitong mga piyesa... Sigurado kasing mahal sa casa at para magkaroon din ng second opinion...
    Pakipost din sana yung purpose ng bawat piyesa sa taas kung may nakakaalam...
    Maraming salamat! :D
    please refer to the related thread in the WORKSHOP forum.
    btw, that problem is very common among 323s.
    nginig? could be engine supports..ako rin e..parang namamasahe ako pag nasa D tapos nakabrake and aircon on..dalhin mo sa prince motors..bihasa yung sarvice manager dun sa mazda..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Aug 2003
    i have a very similar problem (nginig pag naka-aircon and braking) pero di naman namamatay yung engine.. 2.0L torque comes to the rescue! :P
    i already replaced my rear and driver-side engine mounts, and the rear mount makes this annoying rattle (replacement kasi, liniha nila yung bolt hole para kumasya, but i think BS lang yun ng gumawa kasi di ko binili sa kanila yung mount). i was forced to get an orig mount for the driver side kasi walang replacement. :P mahal pa naman yun.
    anyway, ayun nanginginig pa rin. i found na merong nagre-repair ng engine mount, pinapalitan yung rubber with polyurethane (naks! parang WRC car!) pero di ko mahanap saan ko tinambak yung lumang rear mount. :P
    Dec 2003
    Nginig? Does the RPM drop?
    I'n my case the curlpit, was the release bearing for the clutch all along.
    When it finally broke affected parts were the clutch disk, pressure plate, melted bearing, flywheel bearing... the damage? 7,500.00
    To think kulang lang yata sa grease??
    Apr 2004
    i have the same problem, may nginig cya pag release ng clutch and pag bukas ng aircon the rpm drops....what should i do? thanks!!!
    try cleaning the throttle body..
    Apr 2004
    thanks bro! anyway where can i find this Prince motor?
    Dec 2003
    New update from the "nginig" coming from the engine. I also went out of the car and pressed the hood down running in idle, tumahimik?! Went to the machanic and asked him to fasten them tighter and "voila!" totally wala nang nginig.
    According to my friend his problem was the engine support.
    Just giving you more things to check out to eliminate the irritating thing.
    prince motors is kia commonwealth..beside niscom (nissan commonwealth)
    Jun 2004
    engine support lang yan, yung 323 ko dati ganyan lang din ang sakit tas pina check ko, sabi engine support lang. tas pinalitan na ng bago then okay na la na nginig pag nasa N.
    yup... engine support nga... weakness ata ng 323 yun...
    Apr 2004
    Thanks for your replies...but yung sa kin it occurs sa 1st gear pag arangkada dun nagkakaroon ng drag...pag naka neutral wala....sa arangkada lng talga lalo na paahon...please help me guys.....Drive Safe!!!
    might be clutch na problema..
    Apr 2004
    I have changed na nga ung clutch master assembly pero ganun pa rin...it happens when the RPM drops...me time naman mataas:confused:
    bro,
    try posting sa www.protegetech.org mas maraming bihasa na mazda owners dun..
    May 2004
    sir C Cube, did you go to the casa to get your engine supports or did you have your personal mechanic replace it for you? Where can i buy Mazda 323F engine supports? I tried asking along Evangelista in Makati and they were (insert sarcasm here) a great help. Help!
    May 2004
    Where can i get original Mazda engine support(ibabaw lang, according to my mechanic), and how much is a reasonable price for it?
    I tried my luck in Evangelista in Makati and all i got was a headache from all the hack store owners there. They were trying to sell me "original" engine support but, it turns out, japanese replacement part lang siya. Kainiz. Real wast of time. I didn't even bother asking the other shops there.
    So, help please?
    Thanks!
    p.s. i drive a 323 Familia po.
    hi papa..(panget pakinggan nun a)
    anyways, autorama sells replacement and original engine supports..medyo mahal lang talaga..
Mazda 323 Problems
