Yung Mazda 323F kasi namin malakas ang nginig kapag nasa N ang kambyo at yumayanig naman kapag nasa D.
Dinala namin sa Ford Balintawak para ipacheck at sinabi nilang nakita na yung problema. Dinala na namin sa kanila ito dati pero sandali lang tumakbo ng maayos yung sasakyan kaya nagdadalawang isip kami na sa kanila ipagawa ulit. Pero, at least ngayon, iba na yung mga piyesang plano nilang palitan...
1. throttle body, throttle hose and throttle position circuit
2. IAC valve
3. air cleaner hose
Baka naman may kilala kayong magaling na mekaniko at shop na may ganitong mga piyesa... Sigurado kasing mahal sa casa at para magkaroon din ng second opinion...
Pakipost din sana yung purpose ng bawat piyesa sa taas kung may nakakaalam...
nginig? could be engine supports..ako rin e..parang namamasahe ako pag nasa D tapos nakabrake and aircon on..dalhin mo sa prince motors..bihasa yung sarvice manager dun sa mazda..
i have a very similar problem (nginig pag naka-aircon and braking) pero di naman namamatay yung engine.. 2.0L torque comes to the rescue! :P
i already replaced my rear and driver-side engine mounts, and the rear mount makes this annoying rattle (replacement kasi, liniha nila yung bolt hole para kumasya, but i think BS lang yun ng gumawa kasi di ko binili sa kanila yung mount). i was forced to get an orig mount for the driver side kasi walang replacement. :P mahal pa naman yun.
anyway, ayun nanginginig pa rin. i found na merong nagre-repair ng engine mount, pinapalitan yung rubber with polyurethane (naks! parang WRC car!) pero di ko mahanap saan ko tinambak yung lumang rear mount. :P
New update from the "nginig" coming from the engine. I also went out of the car and pressed the hood down running in idle, tumahimik?! Went to the machanic and asked him to fasten them tighter and "voila!" totally wala nang nginig.
According to my friend his problem was the engine support.
Just giving you more things to check out to eliminate the irritating thing.
engine support lang yan, yung 323 ko dati ganyan lang din ang sakit tas pina check ko, sabi engine support lang. tas pinalitan na ng bago then okay na la na nginig pag nasa N.
Thanks for your replies...but yung sa kin it occurs sa 1st gear pag arangkada dun nagkakaroon ng drag...pag naka neutral wala....sa arangkada lng talga lalo na paahon...please help me guys.....Drive Safe!!!
Originally posted by c_cube engine support lang yan, yung 323 ko dati ganyan lang din ang sakit tas pina check ko, sabi engine support lang. tas pinalitan na ng bago then okay na la na nginig pag nasa N.
sir C Cube, did you go to the casa to get your engine supports or did you have your personal mechanic replace it for you? Where can i buy Mazda 323F engine supports? I tried asking along Evangelista in Makati and they were (insert sarcasm here) a great help. Help!
Where can i get original Mazda engine support(ibabaw lang, according to my mechanic), and how much is a reasonable price for it?
I tried my luck in Evangelista in Makati and all i got was a headache from all the hack store owners there. They were trying to sell me "original" engine support but, it turns out, japanese replacement part lang siya. Kainiz. Real wast of time. I didn't even bother asking the other shops there.
