Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Dec 2003
    stuck brake piston? happened to my civic dati hehe just guessing
    Feb 2004
    did you change your rims? baka mali ang offset?
    andy
    Feb 2005
    guys tanong ko lang, may kinalaman ba yung problem ko sa break master? Kasi nagpalit din ako ng brake master eh. sorry ngayon ko lang naisip ito. di ko na nasabay sa post ko sa taas. thank you po ulit.
  4. #14
    malamang....check the all,e..backjob mo..just to get your money's worth..next time,kung maari,sa iba ka na magpagawa...
    Speedyfix in Pasong Tamo or GlennSter's shop in QC ang mga shops na naiisip ko ngayon.
    speedyfix pasong tamo? hindi ba sa santolan sila? :D
    Feb 2005
    Ok, thanks everybody. This weekends puntahan ko si speedyfix.
    baka hindi naka align brake pistons. tabingi then nag stuck na. There is also such a thing as the pads being too thick for your disk. Check your wheel bearings too. A little heat is normal as the pads are always in contact with the rotor disk.
Mainit Masyado ang Rims
