Results 11 to 18 of 18
Tsikot Member Rank 4
- Feb 2004
- 1,704
- Feb 2005
- 28
February 8th, 2005 10:52 AM #13guys tanong ko lang, may kinalaman ba yung problem ko sa break master? Kasi nagpalit din ako ng brake master eh. sorry ngayon ko lang naisip ito. di ko na nasabay sa post ko sa taas. thank you po ulit.
February 8th, 2005 12:23 PM #14
malamang....check the all,e..backjob mo..just to get your money's worth..next time,kung maari,sa iba ka na magpagawa...
February 8th, 2005 12:25 PM #15
Speedyfix in Pasong Tamo or GlennSter's shop in QC ang mga shops na naiisip ko ngayon.
- Feb 2005
- 28
February 10th, 2005 08:22 AM #18
baka hindi naka align brake pistons. tabingi then nag stuck na. There is also such a thing as the pads being too thick for your disk. Check your wheel bearings too. A little heat is normal as the pads are always in contact with the rotor disk.
high idle RPM at engine start
