Results 1 to 10 of 12
September 25th, 2005 01:36 PM #1
This might not be big of a deal but hell these bushings really annoy me because i need to visit the my mechanic to have them replaced at least 2 - 3 times a year (upper and lower - 8 lahat)...ganon b talaga kabilis masira even if most of the time, wla namang load yung bed? I just use the ordinary rubber bushings that cost less than P50...are there other types like plastic or any other with better quality? kse parang d naman sha ganon kadalas masira before...to those pickup users or ones with leaf spring suspensions, would really appreciate inputs!
- Aug 2005
- 13
- 72
September 27th, 2005 11:14 AM #4
Hi red888 and 4xtwo, what pickups are you using? I also have problems with my fuego's bushings. Mabilis masira. Where can we buy polyurethane bushings? salamat
- Aug 2005
- 13
September 27th, 2005 09:12 PM #5Originally Posted by fuego4x2
- Jun 2005
- 3,774
September 27th, 2005 10:27 PM #6pano mo nalaman na gastado na yung bushings mo? i drive an old school lancer that uses leaf springs... had the bushings changed almost two years ago. so far so good. i use the ordinary rubber sa autosupply for 25pesos...
September 28th, 2005 01:10 PM #8
From experience, OEM bushings or polyurethane bushings will work better. The replacement ones don't last long on pick-ups it seems.
With polyurethane bushings, it is said though that they can also be squeaky if not lubricated from time to time.
September 29th, 2005 06:50 AM #9
hmm...looks like problem is common with isuzu pickups...i also have the TFS (a year before the fuego came out)...btw, i got a new set of bushings...the dealer said its the same as the OEM ones, and has japan markings around it...mas mukhang pulido...sana tumagal! they were easier to fit as well, unlike the replacement na talagang pilit ang pasok. i got them for P60 each.
September 29th, 2005 06:52 AM #10
may sinasabi ren pala yung mechanic na nagkabit na mas ok daw yung kinakabit ng mga passenger jeeps...the colored orange ones...eto yata e plastic! sa banawe daw madami.
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
