Results 1 to 20 of 21
    Agree.
    Usually it's the auxillary fan for the condenser (ayaw umikot or masyado mabagal). Pero ang mahal ng assembly niyan (Pajero is Php3,500 up, hindi pa brand new). I just get the motor and use the other existing parts (Php1,500-1,800 ang motor). Ang motor ng aux fan ko ngayon ay Toyota ang tatak pero Denso din and same part number.
    It wouldn't hurt to get a 2nd opinion from another shop. Hindi naman siguro magtatampo ang shop mo.
    Having tinted windows does lessen the work of the a/c. But not having tint will not prematurely destroy the a/c. After all, it was designed to work in other markets (with similar or hotter weather) where tinting is generally not allowed.
    Aug 2006
    Agree.
    maraming maraming salamat smooth and otep
    Sep 2008
    Up ko lang, Otep, will you then recommend to upgrade to laminated evaporators considering it is more expensive than the serpentine ones for a faster rate of cooling as what Smooth explained earlier?
    Smooth, on the assumption na parehong pareho ang gawa ng laminated and serpentine evaporators and kasya sa housing, even na mas mabilis ang rate of cooling ng laminated and is more expensive which is given, you will still prefer to stay stock as you mentioned?
is laminated condenser better than the normal type?
