Results 1 to 10 of 19
November 20th, 2006 02:27 PM #1
pag gamit ko ung car may kaskas na tunog sa left front breaks ko, paputol putol ung sound na kaskas.. nagpakabit ako ng break clips kasi kulang na pero ganun pa din, parang lumalala pa ata, la nman ata problema sa break disk, makapal pa ung break pads.. hmm
if i do hit on the break mejo nawawala ung sound, anu kaya un?
November 20th, 2006 03:20 PM #2
parang metal to metal contact ba? check mo yung pads mo, baka nagstick. pwede rin pudpod na yung brake pads mo... time to replace them.
November 20th, 2006 04:24 PM #4
*ssaloon: uu parang metal to metal ung kaskas, break pads are still makapal, kasi pinalitan ko ung a couple months back kasi kala ko ung ung sira, nde nman nwala
*t2erns:anu po ung backing plate?
any other suggestions?
November 20th, 2006 05:40 PM #5
backing plate yung parang lata sa likod ng brake rotor to protect the rotor sa mga stones atbp may clearance yun sa rotor check mo visually baka sumasayad sa rotor.
November 20th, 2006 07:13 PM #6
pag backing plate ba tuloy tuloy ung kaskas? ung sakin kasi paputol putol ung kas kas parang umiikot ung kas kasi may point lang kung san kakas kas sha
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 20th, 2006 11:45 PM #9
Meron ding ganitong soung sa Lancer MX ko. Weird, nanotice ko lang itong mga tunog na ito sa mga Mitsu Adventure at Lancer. Di naman common sa ibang models/cars. Ba't kaya?
Chineck ko na rin brake pads ko makapal pa naman. Visually wala rin naman ako nakikitang nagstuck contact sa disc.
- Aug 2004
- 243
November 21st, 2006 12:00 AM #10Meron din yan sa auto ko, was find out by my mechanic that the problem lies in the hydrolic cylinder of the brake.. the one with gasket..
Too many trucks in Marcos. Naguilan is too far coming from the south. So Kennon is a lot faster.
2023 Toyota Wigo
