Results 11 to 20 of 36
November 7th, 2002 01:02 AM #11
bump ko lang para malaman kung san maganda pa-check ng whole suspension...
- 135
November 7th, 2002 12:19 PM #12ah.... dati nagpagawa ako sa banawe technicar ok naman.,..
sa class-a banawe ok din daw yata gumawa eh...
- 1
November 7th, 2002 12:53 PM #13oo nga naman!
san po maganda magpagawa/ estimate ng suspension repairs....
yung mura n maganda services
thanks
- 12
November 7th, 2002 01:28 PM #14underchassis diagnostics libre sa midas/rapide. padiagnose ka and pag nadetermine yung problem sa iba ka magpagawa mahal kasi sa kanila. alternative .... sa tyre pro and servitek sa pasig kapitolyo, united street isa lang me ari. dun ako nagpa-align ni-libre na yung pa-retighten ng ilalim.
- Nov 2004
- 8
November 10th, 2004 01:03 AM #15Considering our road conditions nowadays, our vehichle suspension maintenance is really adding up to our budget...thus i would like to inform you fellow filipino that there is a new improved technology of renovating suspension joints.....(ball joints,rack end,tie rods, stab links etc)..the injection system, a special prelubricated formulated polymer is injected to the joints to replaced worn out plastic bush..No press, no cut or weld ,no shims, no gimmiks. the polymer is Industrial grade, thus better than the OEM..renovated joints will last more than 100000kms on normal driving condition. Considering our roads here in the phil., the shop guarantee is 15000kms. better to renovate those OEM joints since metallurgy of the casing is far better than the replacement 555..will surely last, but worn out 555 can also be repaired, by injecting this polymer will become stronger.
Savings on renovated joints is 85-90% cheaper than new OEM, and 65-75% on replacement ones.
thus try to consider this alternative which is effective and economical. For imported cars which are hard to purchase replacement and are so expensive , and local jap cars...renovate dont replace .Last edited by toticruz; November 17th, 2004 at 02:59 PM.
March 7th, 2005 05:41 PM #16
Mr. toticuz ako po yung nagpaayos sainyo last wed march2 black honda civic.. Thank you po nawala na ang mga ingay. masarap na ngayon magdrive wala na ang mga nakakairritate na ingay.I try po nyo at im sure masasatisfied kayo sa results.
March 7th, 2005 05:57 PM #17
sir toti..ride ko delica 4wd...ask ko lang..
in time ba normal mag-squeak ang rear leaf springs on its bolts?
so as ung sa harap,stabilizer bushing bolts make a "tok" sound then the supension is playin?
qc area po ba kyo?pwede pm nyu din shop nyo and direction? to check nyo po visually ang sasakyan...napalitan na po lahat ng parts sa ilalim,using orig. 555 replacement parts and KYB gas shocks,including the bushings...pag may time punta po ako.
btw,i sometimes purposely drive the van up to waist deep waters when the need arise..and rarely regrese the bushing bolts.
thaxz po!
March 7th, 2005 06:50 PM #19
saan nga ba yang shop ni toticruz na yan? qc area lang kaya?
- Sep 2004
- 34
March 7th, 2005 07:45 PM #20mga sir nangyari narin yan sa car ko...pinatingin ko sa mga mikaniko d nila makuha kung saan ung tumutunog ,diba tunog nyan parang langitngit ng spring? ang usual na problema nyan suspension,baka replacement lang ung nakakabit sayo..check mo rin, me alam ako casa ang galing sa kalampag sila lang nakapagpatangal ng langitngit ng car ko..sa Q.C. MAR-BEL MOTOR SHOP...ang sarap i drive ng walang tumutunog...he he he
Any reviews for the Triton GLX 4WD 6MT? Siya ata pinakasulit na middle 4WD variant. Price range...
2022 Mitsubishi Strada/Triton (6th Generation)
