Results 1 to 10 of 19
- Dec 2004
- 98
September 26th, 2005 02:37 PM #1help!
my ride is galant ss 96 m/t.
anu kaya possible problem, matagal mag rev un car...so mabagal magaccelerate....miski tapak ka ng todo sa gas....
mahirap bumatak ang car...
it will reach running speed of 80kph...at rev 3000rpm....
kaso ang tagal talaga magaccelerate...
what could be the possible prob?
san maganda ipagawa? magkano kaya gastos?
TIA!
- Dec 2004
- 98
September 26th, 2005 07:50 PM #3iniisip ko baka clutch prob...di ba ganito rin manifestation non?
tom dalahin ko sa talyer....hay gastos!
anu kaya ito???
September 26th, 2005 10:06 PM #4
possible din sliding clutch ka if your engine seems to rev fine when not moving...
Search ka about "sliding clutch" para malaman mo symtomas.
- Dec 2004
- 98
September 27th, 2005 01:44 PM #5yep that's it....rev but not moving...tapak ng tapak sa gas....ala lang...the rev needle jus kept on rising....
nagcanvass ako ng parts...kailangan ba talaga palitan din ang clutch fork? saka kailangan daw ireface bago ilagay un mga bago na parts....
hay...hay....hay....
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 3rd, 2005 10:46 PM #8probably the clutch nga... disc, pressure plate and release bearing.
if may extra budget replace the oil seals and pilot bearing narin.
should only take a day to replace everything.
- Dec 2004
- 98
October 6th, 2005 03:46 PM #10
ang alam ko mura lang ang clutch fork eh...
refacing meaning the flywheel face? if it costs similar to brake disk refacing, dapat mura lang yun (refacing a brake disk costs like 300) pero mahirap ibaba yung flywheel..
replacing all the clutch-related parts would probably cost around 8000 inclusive of labor.
