I'm getting my timing belt, tensioners, oil seals changed and inner drive shaft boot changed. Para bawas sa gagastusin (which is 20k more or less kung sa casa), I would like to get this done outside besides the casa. Anyone know of a place with 'ok na ok', 'bang-for-the-buck' shop?
will not cost you some 3k for everything yan dapat kung sa mekaniko na mabait ka papagawa :-) or maybe less :-)
cv boots usualy at 200(both na dapat)
timing belt seldom exceeds 700 for orig
bushings usually at 50 to 150 for the ordinary rubber stuff
oil seals are cheaper ;-)
labor for everything ay 700 at least hehehe
ball park figure lang ito...unless u want something special done or bibili ka ng special parts tataas yan hehehe
don't think your prices are accurate. replacement timing belts may be that price but oem ones are 1k and up. plus tensioner bearings, water pump, oem oil seals, etc.
