Got mine from Speedyfix. Makes no difference whether you use it on Gas or Diesel engines.Originally Posted by fuego4x2
Meron akong kilala nagbebenta ng grounding kit, Mark name nya, he is along beundia lapit lang lrt station bale sa kanila yung Alpa Battery supply. Meron din syan ibang jdm parts. Ito number nya kung may interested 832-3729, sabihin nyo ni refer kayo ni jeff(that's me!!...hehehe). ot: sa kanya din ako nagpakabit ng tube, filter and carb adaptor para sa mitsu ko.
nagastos ko sa grounding kit ko DIY 200 petot lang. i bought the wires and connectors plus the shrink wraps sa suking auto shop.
price will depend on the gauge that is used. the thicker the wire the more expensive it will be.
gauge 8 less than 1k, gauge 4 less than 2k.
these are for the groundwires na imported. not home made.
Jag, Magkano yung kit niya? Kasama na ba yung kabit? Anong gauge ang gamit niya?Originally Posted by jag_001
ganyan din yung kulay nung binili kong gauge 4 copper stranded wires. 25 pesos per feet and i used around 5 feet for my DIY grounding kit. yung mga connectors at shrink wrap mura lang.Originally Posted by finchy18
jim: pics naman ng DIY project mo. :D 8 gauge ba o 8 gauge gamit mo?
speedyfix: may stock pa ba yung 4 Gauge grounding kit?
kahit luma po kotse, pwede naman pong i-DIY grounding ryt? since poor grounding na ang chassis ko and needs to be latero-ed na. haha.. sa Raon po ako malapit and alam ko po yung shop na Deeco.. pwede po bang paki list po ulet yung mga things na kelangan for DIY Grounding? thanks po! and mas lower number ng gauge, mas makapal ang wire, ryt? thanks po! and ground won't start a fire or explosion kung sakaling may magleak man na fuel ryt? thanks po ulet!!!
malaki ba difference pag may kasamang volt regulator a.k.a. volt stabilizer?
for example: plain grouding kit vs. grouding kit w/ volt regulator(may isang maliit na block na may maliliit na capacitor *un ba tawag doon?* hehe) thanks.
Daming threads nito dito ah. Anyway ito yung DIY namin sa club site, courtesy of dotph:
http://kiaprideclub.proboards55.com/...ead=1169622375
compressed into pdf format. attached to this post.
OT: Request to the MODS concerning to CONSOLIDATE/MERGE ALL 'GROUNDING KIT, DIY GROUNDING et al and other related from this technical topic to avoid more confusion & complication, mostly to some new tsikoteer forumers.
Making this STICKY would be BEST, TY!:D
