Results 1 to 20 of 20
    Apr 2008
    mga sir,
    while driving the other day i accidentally shifted from 3rd gear to neutral without stepping on the clutch. sabi ng friend ko sya nga daw minsan nag shi-shift sya ng gear without stepping on the clutch from 2nd to 3rd and so on. wala naman daw grinding noise. any thoughts on this? TIA.
    technically, being in gear means that naka lock sa gear yung sasakyan and you need the clutch to disengage from the lock.
    baka may masira dun sa transmission.
    nagtataka din ako, matigas yung kambyo from a gear to neutral ah, pano nya ginawa yun?
    Oct 2011
    Ginagawa ko din yan gear to neutral hindi naman mabigat pag shift. pag gear to gear ayun, need mo talaga apakan clutch matigas na kasi un.
    Jan 2008
    basta naka match yung engine speed sa transmission speed at sa vehicle speed makaka shift ka without stepping on the clutch...
    smooth shift yan..
    Yup. Minsan sobrang pagod ko nakakalimutan ko mag-clutch from gear to neutral. Pumapasok naman, tapos kapag narerealize ko, nawawala pagod ko at mas nagiging alert.
    Meron sa Youtube ganyan, search niyo nalang: Clutchless shifting. I'm not sure if this is safe at all. Kung ayaw naman mag-clutch, mag-automatic nalang kaysa i-risk pa transmission niyo.
    Aug 2004
    smooth shift yan..
    Easy-peasy. Let off the gas a little so you can pop it into neutral, then rev it up to the proper rpm if you're downshifting or let the revs drop if you're upshifting.
    Easier to do on some cars than others. I sometimes do this in my truck when my feet hurt. Tend not to do it on test units, as it's not my synchros I'm grinding when I get it wrong.
    Apr 2008
    thanks mga sirs sa inputs. medyo nag worry lang kasi ako baka may sira sa transmission ko nung na shift ko from gear to neutral.
    if there's no grinding noise, then it's not hurting the trans..., right?
    .. in this context only...
    Aug 2004
    Yup.
    Clutchless shifting is a useful skill to learn. The skill in timing your shifts and rev-matching developed by practicing this also helps you to shift smoother with the clutch, leading to longer clutch life.
    Nov 2011
    eto yung video. Pinoy yan!
    Never really knew that it's possible to shift to neutral until tonight, accidentally. I thought of it previously but never tried. Clutchless shifting is another matter though.
    Quote Originally Posted by sphinxz View Post
    Just rev match to shift into your desired gear. First saw this on Top Gear many years back, been using it as a party trick whenever someone rides my car ever since.
    Bad for the synchros of your transmission, but pretty cool trick every now and then, and very useful skill to learn if you ever have to deal with a broken clutch.
    So how would you know its time to shift? Does it vary in every gear and car type? Or is there a standard rpm?
    Yes it varies per gear and car.
    You have to memorize your car's rpm per gear at any given speed.
    For example, you're in second gear at 40 kph at 3000 rpm. You let go of the throttle, slide the shifter back to neutral, then you have to rev match it to the exact rpm that would match 40 kph in 3rd gear. This is likely be 2000 rpm, so you step on the gas a bit to get the revs up to 2000 rpm, then you stick the shifter into 3rd gear.
    Rinse and repeat for any gear.
    Apr 2017
    Ginagawa to ng tito ko sa nangangalawang na niyang pick up. Yung pang harabas. HAHHAA
    Sent from my SM-G928V using Tsikot Forums mobile app
    Thank you for explaining. Won't use it anytime soon though. Wala pang pangpractice na car.
Changing Gear Without Stepping on Clutch
