Results 11 to 20 of 20
- 52,698
March 1st, 2013 08:05 PM #11if there's no grinding noise, then it's not hurting the trans..., right?
.. in this context only...
- Nov 2011
- 428
- Mar 2013
- 19
March 17th, 2013 09:09 AM #14ang clutch po ay nilagay para makambyo natin ang sasakyan... kaya kung hindi mo gagamitin masisira lang ang sasakyan mo.... Cs po
- Jan 2015
- 714
May 16th, 2017 11:01 PM #15Never really knew that it's possible to shift to neutral until tonight, accidentally. I thought of it previously but never tried. Clutchless shifting is another matter though.
May 16th, 2017 11:07 PM #16
Just rev match to shift into your desired gear. First saw this on Top Gear many years back, been using it as a party trick whenever someone rides my car ever since.
Bad for the synchros of your transmission, but pretty cool trick every now and then, and very useful skill to learn if you ever have to deal with a broken clutch.
- Jan 2015
- 714
May 16th, 2017 11:36 PM #17
- Apr 2017
- 123
May 16th, 2017 11:47 PM #18Ginagawa to ng tito ko sa nangangalawang na niyang pick up. Yung pang harabas. HAHHAA
Sent from my SM-G928V using Tsikot Forums mobile app
May 17th, 2017 01:32 AM #19
Yes it varies per gear and car.
You have to memorize your car's rpm per gear at any given speed.
For example, you're in second gear at 40 kph at 3000 rpm. You let go of the throttle, slide the shifter back to neutral, then you have to rev match it to the exact rpm that would match 40 kph in 3rd gear. This is likely be 2000 rpm, so you step on the gas a bit to get the revs up to 2000 rpm, then you stick the shifter into 3rd gear.
Rinse and repeat for any gear.
- Jan 2015
- 714
May 17th, 2017 10:34 AM #20Thank you for explaining. Won't use it anytime soon though. Wala pang pangpractice na car.
Thank you!
