Results 1 to 13 of 13
    Jan 2014
    Hi Guys i just need some of your time to add car maintenance checklist on this post
    Very Newbie po kasi ako and medyo noob sa pag follow sa manual so i hope you can help me with this
    Saka one of my inquiry is some guys told me here na Timing Chain ang toyota vios 1.5g so pano ang maintenance ko don? kasi i have 166,000 KMS na on my odometer
    here are some of the maintenance that i know please feel free to add
    thank you guys and i appreciate your help!
    (Every 3 months)
    Change Oil - semi synthethic
    Change Oil , Fuel , Air Filters
    Engine Wash
    (Every 6 Months)
    Tire Rotating + Balancing
    Wheel Alignment + Camber
    Full Throttle Body Cleaning
    MAF Sensor Cleaning
    Under Chassis Wash
    (Every 12 Months)
    Change ATF Fluid
    Change ATF Filter
    Radiator Flushing and Coolant Replacement
    Replacing Break Pads and Break Fluid
    Replacing Power Steering Fluid
    (Every 24 Months)
    Car Battery Replacement
    Eto lang po alam ko eh i dont know what maintenance should i follow pa aside from this and im thinking na mas dalasan ko yung pag change ng ATF fluid gagawin ko sana every 6 months , saka yung sa timing chain i dont know how to maintain it or ano gagawin or irereplace.
    Just bought the car last january and im rarely using the car ( 2-3 times a week ) pero pag ginamit ko naman talagang gamit na gamit naman . recently na mga pina service kona is coolant replacement and radiator flushing , change oil replace air fuel oil filters , change atf fluid , wheel alignment and camber .
    please add some maintenance on my checklist thanks so much guys .
    Jun 2005
    dont do an engine wash if the engine is still hot.
    btw, make sure the ATF you use is toyota type IV (for 1st gen vios).
    additional info is to inspect the thermostat of you cooling system when you flush the fluids.
    Sent from my Thrill 430x using Tapatalk 2
    Aug 2012
    Timing chain
    Timing chain typically last longer than the life of the car. A car can last 40 years and never need change the timing chain. You only replace it when it gets broken. In comparison, timing belt may need replacement every 150,000 km.
    Change oil, Oil filter
    -Mineral, replace every 5,000 km or 6 months (whichever comes first)
    -Semi-synthetic, replace every 7,500 km or 9 months (whichever comes first)
    -Fully synthetic, replace every 10,000 km or 12 months (whichever comes first)
    This is my own list for reference only. Please check your Owner's Manual for specific info about your vehicle's maintenance.
    As needed
    -Car wash
    -Engine wash
    -Underchassis wash
    -Undercoating/Rust-proofing
    -Interior detailing
    -Exterior detailing
    -Glass detailing
    Monthly (or more often)
    -Check tire pressure
    -Check oil level
    -Check coolant level
    -Check ATF level
    -Check washer fluid level
    -Check brake fluid level
    -Check battery (Replace when needed)
    Every 6 months
    -Check power steering fluid
    -Wax car to extend life of paint/prevent rust
    -Inspect all lights, horns, wipers and washer
    -Buff plastic headlight assembly if dull (to maintain good visibility)
    -Inspect brake pads and discs (Replace when needed)
    -Inspect brake pedal and parking brake (Adjust when needed)
    Every 12 months
    -Replace wipers
    -Rotate tires (Replace when needed)
    -Inspect spark plugs (Replace when needed)
    -Inspect hoses and clamps (Replace when needed)
    -Clean battery connection
    -Inspect and clean air conditioner system
    -Grease wheel bearing
    -Inspect shocks for leaks and perform bounce text (Replace when needed)
    -Inspect U-joints (Replace when needed)
    -Inspect or clean air filter (Replace when needed)
    Every 2 years
    -Flush radiator
    -Replace coolant
    -Replace brake fluid
    -Inspect drive belts (Replace when needed)
    -Adjust Idle speed, Idle mixture
    Every 4 years
    -Replace differential gear oil
    -Replace ATF
    -Replace fuel filter
    -Clean throttle body
    Jan 2014
    Quote Originally Posted by sirkosero View Post
    Noted thank you so much sir
    BTW may alam ba kayong good car repair shops here in the south? Alabang BF Homes Area. kasi yung kakilala kong Mekaniko na service advisor ng good year ang layo eh sa quezon city pa sila , im looking for a shop na malapit sa place namin Im from BF homes paranaque lang thanks in advance !
    Jan 2014
    Quote Originally Posted by red_one View Post
    Timing chain
    As needed
    -Car wash
    -Engine wash
    -Underchassis wash
    -Interior detailing
    -Exterior detailing
    -Glass detailing
    -Check oil level
    -Check ATF level
    Every 6 months
    Every 12 months
    -Replace wipers
    Every 2 years
    -Flush radiator
    -Replace coolant
    Every 4 years
    -Replace ATF
    Very Informative thank you so much sir
    What kind of drive belts do i have sir? saka how many drive belts? I really dont have an idea sorry
    and how will i know if my timing chain needs replacement na or if its broken? I already have 166,600 KMS on my odo
    Also if you can recommend a good car repair shops here in alabang i would really appreciate it thank you!
    Jan 2014
    Quote Originally Posted by KrisVios04AT View Post
    (Every 3 months)
    Engine Wash
    (Every 6 Months)
    Tune Up + Replacing Spark Plugs
    MAF Sensor Cleaning
    Under Chassis Wash
    (Every 12 Months)
    Change ATF Fluid ( Toyota Type IV - 1st Gen Vios )
    Change ATF Filter
    Replacing Drive Belts
    Aircon Cleaning
    (Every 24 Months)
    Updated Please add more yung mga recommend niyo this will help me so much thank you guys
    Jun 2005
    unfortunately, no. im from makati but my brothers have their cars fixed at prens, cruven or at pitworkz. all of them in sucat
    Jan 2014
    I'll try at cruven , palitin na ata mga suspension parts ko eh , matagtag na ride ko pag sa rough road , sa patag ok pa naman
    tapos nag wiwiggle na yung steering wheel ko pag rough road , what parts should i replace in instances like this?
    Jun 2005
    it can be as simple as wheel balancing or baka suspension overhaul yan....
    may kalampag din vios gen1 namin. pinaestimate ko sa crucen. estimate nila is about 7.5k for refurb of ball joints, rack end, replace stab link, and big suspension bushing.
    if you want to lower the cost pwede ka magdala ng parts mo. example the big bushing costs 350 sa auto supply. 550 na sa cruven. yung stab link naman 350 din sa autosupply 950 naman sa cruven.
    yung injection naman para sa balljoints ay okay.
    wag mo pala iparefurbish ang shocks. pangit ride quality pag ganun
    Jan 2014
    Thanks Sir this helped a lot ! will defenitely visit cruven
    sir wala ka ba manual? nasa manual lahat yan eh, kung dapat inspect (I) at ano dapat replace (R).
    Mar 2017
    Hello Sir,
    Do you happen to know any shops that does the scan for VIOS 2nd gen?
    I am having the same trouble mine is VIOS G 1.5 MT 2010.
    I tried to change my spark plug it was fixed but after a few weeks bumalik ulit, any shops that can cater my needs near san juan?
    Thank you thank you mga papi!
    Jun 2005
    Try speedyfix.
    Ano ba nangyayari sa car?
Car Maintenance Checklist for Toyota Vios 1.5G Automatic Trans 2004 model
