Results 1 to 10 of 11
October 21st, 2003 02:14 PM #1
need help...
it happened last night. my ride suddenly stops when i turn on the stereo. seems there is an electrical problem. what could be the reason? ride is a toyota corolla gli 96 a/t. thanks!:confused:
October 21st, 2003 03:18 PM #2
Naka sound set-up kaba? headlight on? aircon on?
if yes on all of the above, my diagnosis is either your alternator is not charging sufficiently or you need to change to a bigger battery.
October 21st, 2003 05:02 PM #3
d naman setup ung sounds. actually m using the stock Alpine casette receiver. Actually di naman agad namamatay ung engine pag on ng stereo. it will take a few minutes before mamatay ung engine. Kaka-change lang ng battery ko Motolite MF and kaka-check lang ng charging system ko sa casa last month.
:confused:
October 21st, 2003 09:22 PM #4
check your electricals baka grounded. when your engine stops pati ba horn and lights nde gumagana?
- 3,754
October 22nd, 2003 12:13 AM #6
m running when the engine stops. how can i check if the electricals are grounded? pina-check ko kanina sa motolite kung ok pa ung battery, they said di raw gumagana ng maayos ung alternator. i brought it to an auto shop, sabi ng mechanic ok naman daw alternator. thanks.
:confused:
November 16th, 2003 08:33 PM #7
jg2003,
baka nga grounded ung electrical system mo. Look up the fuses kung may busted.check the wires for anything out of the ordinary. discoloration or ung tunaw na wire.have it checked up by a good car electrician.
November 16th, 2003 11:25 PM #8
buti stop lang, minsan sakay ko erpats ko nagpasak ba naman ng tape nya na ballroom. eh nung cha-cha na yung music, umatras kotse ko!
joke lang wag galit! smile!
ok serious na...
i think tama yung sabi ng battery shop, patay na alternator mo. so you're just running on your battery kaya pag on mo ng ibang load, drained na sya.
- Aug 2003
- 125
November 17th, 2003 11:29 AM #10dalhin mo sa auto eletrical. ang alam ko magaling sa ganyan eh sa Wizzards Tomas Morato near E. Rodriguez. pero kung mukhang di ka makakarating dun kakapatay, sa pinaka-malapit nalang. mahirap yang ganyan sa daa, mahihiya ka kasi nakaka-abala ka pag namamatay.
nagapalit ako ng pang-ilalim kahapon so takbo ako magpa- alignment service maybe tomorrow. ...
Wheel Alignment
