Results 21 to 30 of 89
March 10th, 2005 09:47 AM #21
aah, so scub pala tawag dun..
yea, maingay nga, how about performance-wise? di ba mga nascar cars walang mufflers? hehe.. seriously, ano po yung ibang nakikita ko na makintab at malalaki ang butas na muffler? freeflow yun? e yung parang tubo lang na parang walang chamber pero malaki rin butas? whats the difference? (kakahiya na, ang engot sa ganitong mga bagay...)
March 10th, 2005 10:24 AM #22
if you can live with the noise on a daily driven car, go for it
but i prefer custom mandrel bent pipes mated with a JASMA spec muffler... ganda ng tunog with the performance gains!
March 10th, 2005 10:39 AM #23
First mods? Sound system... DIY lang, so did a LOT of research and asked a LoT of questions in Forums like this.
March 10th, 2005 02:09 PM #24
so...am i on the right track, iluvdetailing? hehe..
i called nodalos, nagpa-consult...so far, dami na plano building up in my mind... mahal nga lang..
March 10th, 2005 02:29 PM #25
Your doing the right thing, the internet is your friend. Just do it one at a time. What are your planned mods? Make a list of mods you want so that you can set a goal... that way it would be easier for you to plan ahead. And regarding performance mods, do you want an N/A or a turbo charged engine?
March 10th, 2005 04:55 PM #26
Actually the first thing to do when you are deciding to modify your car is what will your car be first? Performance? Audio/Entertainment? Porma?
If you want performance, you have to upgrade the engine, brakes, suspension, wheels, etc. You will also have to keep the weight down so you cannot install big subwoofers, etc. Also some bodykits and big wheels do nothing but slow you down (aside from looking good).
If you want audio, you can keep the exterior nearly stock and concentrate on your speakers, amplifiers, enclosures, head unit, etc. You might need to install some additional soundproofing and foam to eliminate excessive vibration and road noise.
If you want porma only... well, I guess you already said you dont want it.
March 10th, 2005 05:00 PM #27If you want performance, you have to upgrade the engine, brakes, suspension, wheels, etc. You will also have to keep the weight down so you cannot install big subwoofers, etc. Also some bodykits and big wheels do nothing but slow you down (aside from looking good).
Why not the best of both worlds?
March 10th, 2005 05:05 PM #28
Originally Posted by ILuvDetailing
Anyway, with most n/a type upgrades, a simple brake pad upgrade would be good enough.
The long list of possible upgrades for performance is meant to maximize the performance potential of the sentra & the ga16de engine.
Why not the best of both worlds?Last edited by ghosthunter; March 10th, 2005 at 05:17 PM.
March 10th, 2005 05:11 PM #29
Here's something I picked up from the nissan casa years and years ago.
The ECU of the GA16DE engine found in the model 1992 Nissan Sentra is programmed differently depending on the transmission that was fitted to it. The A/T version was programmed to have slightly more torque at the lower RPM range than the M/T version. They said it was done this way to offset the power losses from the A/T tranny. It was also said you can swap engine ECUs from the A/T to a M/T version car and gain some lower end torque without affecting max output HP in a M/T tranny Sentra.
March 10th, 2005 07:19 PM #30
hmmm..nice info..
lets get back to my previous questions though..hehe.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
