Quote Originally Posted by manolop10 View Post
Hey guys, i'm a newbie with setting cars up, and i have a question on lowering my car, its a '98 BMW E36 316i. My rear coil springs have already settled really low, and i had the shocks replaced already, mababa pa rin. And if you guys noticed, most of the Euro cars have a negative alignment with the rear wheels. So meaning yung kain ng gulong, sa loob rin. I noticed on the brand new tires i replaced, only after 3 months, medyo napudpod na yung goma sa loob. I wanna know if replacing my springs to lowering springs, ganito pa rin ba mangyayari sa negative alignment ng rear? Or should i just replace the rear springs to factory height to have egual alignment? Is there a way to put lowering springs sa car pero maayos pa rin alignment niya or ganun talaga pag mas lowered?
Take note, the alignment of the car can only repaired from its sides, yung left to right and vice versa lang, wala sa positive negative position.
Thanks!!
Are you saying that you can only adjust the caster but not the camber on your car? Also how many Km are on the tires since you installed the new ones, maybe it's time to rotate your tires. That's determined more by the distance travelled by the tire rather than the time it's been on the car. It seems a little early for your springs to be sagging so soon, normally car makers put in a bit of negative camber to prevent oversteer on rwd cars.
