*speedyfix - I figured that would be the result, but i never knew there could be those camber coorrection devices! Would you know where i can look for those? Can your shop check my suspension?
*redorange - Thanks for giving the correct terms. Yes only the caster may be adjusted and not the camber. The new tires have only about 5000kms on them. The springs are 10 years old and surely this is enough time for them to sag and settle this low. I will rotate the tires but isn't this too soon?
*M54powered - i'll have my suspension checked, but i already had the rear bushings and shock absorbers changed, so that leaves the springs left AFAIK. anymore to add?
Thanks for the reply guys. A lot of help so far, just need the time to have it checked then. Can you suggest a place? I go to European Motors but they can be overkill sometimes. I'd like to try other experienced places. I appreciate the help! Thanks again!
